| Re: Gideros Code Assist [message #972520 is a reply to message #970797] |
Mon, 05 November 2012 12:44  |
Marc Aubry Messages: 39 Registered: August 2012 |
Member |
Hi Hilman,
This is a better thread to talk about Gideros
Some points:
* Be sure you have correctly add the EE to your current project, when the EE is added, you it appear in the script explorer as a node under the project.
* To have a outline, with more than first level variable, use Lua Documentation Language to document your code as explain here.
If is still not working, please tell us with more detail want to try to do. Maybe by sharing some code, or attaching your project and EE.
Marc
[Updated on: Tue, 06 November 2012 08:26] Report message to a moderator
FUDForum. Page generated in 0.01698 seconds
