Home » Eclipse Projects » Jubula » Screenshot comparison
Screenshot comparison [message #882703] Wed, 06 June 2012 22:30 Go to next message
Andrew H is currently offline Andrew H
Do you guys have any plans to provide an action for comparing screen shots?
While this isn't a preferred method of testing output, our application makes used of Java3D and we were looking at a simple way of verifying graphical output as part of a Jubula test case. The use case would be:
1. Perform test setup
2. Capture screen shot, only capturing the Java3D rendering region.
3. Compare this screen shot to saved screenshot. This comparison could be a simple pixel-wise comparison.
Our current intention is to use the executeExternalCommand action to do this, but I think would be a useful feature to have built into Jubula.
Re: Screenshot comparison [message #882770 is a reply to message #882703] Thu, 07 June 2012 02:58 Go to previous message
Achim Loerke is currently offline Achim Loerke
We have looked into this and actually have evaluated a toolkit which would support this kind of actions. Only problem: so many ideas, so little time! So it will be there sometimes in the (not too far but not immediate) future (meaning probably Kepler).
Again, if you can provide help or sponsor the development, things will go faster.
Previous Topic:Suggested built-in actions for database, file manipulation
Next Topic:Jubula, CI and Version Control
Current Time: Wed May 22 13:20:35 EDT 2013
Powered by FUDForum. Page generated in 0.04838 seconds
