Home » Eclipse Projects » BIRT » Filtering crosstab data by dates(crosstab filter)
Filtering crosstab data by dates [message #882087] Tue, 05 June 2012 16:29 Go to next message
Shayne Paddock is currently offline Shayne Paddock
I have a dataset that returns values for the past year. I create a last 12 month crosstab based on that.
I also want to show the last 12 weeks of values as well using the same dataset as above. I've set up my dimensions to be year and week of year. How do I only return the last 12 weeks of data for that particular crosstab?
I'm running BIRT 3.7.1
Kindest regards,
Shayne
Re: Filtering crosstab data by dates [message #882140 is a reply to message #882087] Tue, 05 June 2012 19:21 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Have you tried using a filter on the crosstab that make use of:
BirtDateTime.addWeek()
Use your date field as the expression and then use a between operator
and then the first value should be :
BirtDateTime.addWeek(new Date, -12) and the second value should be
new Date
Jason
> crosstab?
> Kindest regards,
> Shayne
Jason Weathersby
BIRT Exchange
Re: Filtering crosstab data by dates [message #882476 is a reply to message #882140] Wed, 06 June 2012 10:27 Go to previous messageGo to next message
it doesn't seem like I have access to the date field from the dataset in the crosstab filter area. I can filter based on dimensions which are year and week of year. Is there a way to get access to filter on the date in the data set?
Kindest regards,
Shayne
Re: Filtering crosstab data by dates [message #882668 is a reply to message #882476] Wed, 06 June 2012 20:06 Go to previous message
Shayne
Take a look at the attached example. You also could make use of the new
relative time period report item described in this post:
http://birtworld.blogspot.com/2012/03/birt-372-new-features.html
Jason
> Kindest regards,
> Shayne
Jason Weathersby
BIRT Exchange
Previous Topic:Problem with namespace on web service parameters
Next Topic:a ReportServiceException while running the report using BIRT Viewer 3.7.1
Current Time: Wed May 22 21:09:40 EDT 2013
Powered by FUDForum. Page generated in 0.04661 seconds
