Home » Language IDEs » Java Development Tools (JDT) » ClassNotFoundException
ClassNotFoundException [message #882415] Wed, 06 June 2012 08:34 Go to next message
Jonathan Camilleri is currently offline Jonathan Camilleri
Member
package coff;
public class Mammal {
static
{ int a = 1;
assert a == 1;
System.out.println("mammal initialized");
package coff2;
import coff.Mammal;
public class Dog extends Mammal {
@SuppressWarnings("unused")
assert (1 != 0) : "this should never appear...";
System.out.println("Dog extends Mammal");
Caused by: java.lang.ClassNotFoundException: coff2.Dog
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
Exception in thread "main"
Re: ClassNotFoundException [message #882475 is a reply to message #882415] Wed, 06 June 2012 10:24 Go to previous messageGo to next message
Eclipse User
Does this have anything to do with Eclipse? This looks like a general
problem running a java jar. This forum is for Eclipse JDT (compilation)
problems/questions. For general java questions you need to go somewhere
else.
Rich
Re: ClassNotFoundException [message #882480 is a reply to message #882475] Wed, 06 June 2012 10:34 Go to previous messageGo to next message
Stephan Herrmann is currently offline Stephan Herrmann
Well, the attached rar contains a proper Eclipse / JDT project.
If the exception occurs when running the application inside the IDE, then something's fishy in JDT/Debug.
Otherwise, (if exception ocurrs outside Eclipse) I concur that the JDT forum is not a likely place to get help for this issue.
Stephan
Re: ClassNotFoundException [message #882505 is a reply to message #882480] Wed, 06 June 2012 11:38 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
I wouldn't say it's a "proper" project--you have two JREs on the Java Build Path, and unless you've actually set up a 1.7 JRE in the preferences, your build path will be considered broken. An erroneous build path will, by default, abort the build and leave you with no class files, hence the Error at runtime.
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:ASPECTJ Internal Compiler Error
Next Topic:Can't get my webapps to deploy from Eclipse
Current Time: Tue May 21 10:58:21 EDT 2013
Powered by FUDForum. Page generated in 0.01886 seconds
