Home » Eclipse Projects » Eclipse Platform » org.eclipse.core.runtime.adaptor.FileManager cannot be resolved
org.eclipse.core.runtime.adaptor.FileManager cannot be resolved [message #881413] Mon, 04 June 2012 10:01 Go to next message
Daniel Frömmel is currently offline Daniel Frömmel
Hi there,
i have to extend Eclipse with environment variable support (related post #357701). So i used the integrated CVS support in Eclipse (tried SDK 3.7.2 and SDK 4.1) and checked out the following branches:
(1) org.eclipse.resource (implements the classes i need)
(2) org.eclipse.runtime (referenced by org.eclipse.resource)
(3) org.eclipse.osgi (referenced by org.eclipse.runtime)
Compiling (1) works, some warnings, but works. Compiling (2) does not work and i cannot resolve the following error:
"import org.eclipse.core.runtime.adaptor.FileManager;
FileManager cannot be resolved to a type"
I searched for the CVS repository "org.eclipse.core.runtime.adaptor" but i cannot find it anywhere.
What am i missing here?
Thanks for helping.
So lonG
Daniel
[Updated on: Mon, 04 June 2012 10:01]
Report message to a moderator
Re: org.eclipse.core.runtime.adaptor.FileManager cannot be resolved [message #882243 is a reply to message #881413] Wed, 06 June 2012 01:41 Go to previous message
Ok, i finally got it compiling by installing Eclipse SDK 3.7.2 and checking out
the source code via the integrated CVS client from
:pserver:anonymous@dev.eclipse.org:/cvsroot/eclipse/Versions/org.eclipse.core.%/%R3_7
instead of
HEAD
I assume that R3_7 means compatibility with SDK 3.7. Total version hell...
[Updated on: Wed, 06 June 2012 01:43]
Previous Topic:ClassNotFound for class in dependency and can't debug
Next Topic:Why plug-in depends on its fragment(s)?
Current Time: Fri May 24 12:38:13 EDT 2013
Powered by FUDForum. Page generated in 0.07446 seconds
