Home » Eclipse Projects » BIRT » Decreasing image quality in PDF-Export
Decreasing image quality in PDF-Export [message #882026] Tue, 05 June 2012 12:49 Go to next message
Thomas Thym is currently offline Thomas Thym
I have written a report generating a price list with images of the product. The pictures have a resolution of 300 dpi. The exported PDF-file goes to the printer. The 50MB file is too big for the download from the internet. (The internet version is individual for each customer with individual prices.)
My aim is to reduce the resolution of the report to 96 dpi. I searched the internet and found some hints.
I tried the following things with no effect.
1. Properties -> Advanced -> Image DPI -> set to 96
2. Add a script to "beforeRender"
reportContext.getAppContext().put( EngineConstants.APPCONTEXT_CHART_RESOLUTION, 96 );
[This one might only work for charts, not for images, but I tried it.]
3. Add a script to "beforeRender"
var options = new PDFRenderOption();
options.setOption(IPDFRenderOption.DPI, 96);
... and many variations.
If would be great if you could give me some hints where I could look into.
Thomas
P.S.: I use birt-rcp-report-designer 3.7.2
Re: Decreasing image quality in PDF-Export [message #882121 is a reply to message #882026] Tue, 05 June 2012 18:22 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Take a look at this :
http://www.eclipse.org/birt/phoenix/project/notable2.5.php#jump_16
Also set the height and width for the image to blank and then set the
advanced property for dpi. You may also want to look at the fit to
container to put your image in a grid cell that is sized smaller than
your image.
Jason
On 6/5/2012 12:49 PM, Thomas Thym wrote:
> Thomas
Jason Weathersby
BIRT Exchange
Re: Decreasing image quality in PDF-Export [message #882125 is a reply to message #882121] Tue, 05 June 2012 18:27 Go to previous messageGo to next message
BTW if you are using charts and you want the pdf smaller make sure to
set the chart type to something like png. SVG produces better image
quality on charts but larger pdfs.
Jason
> your image.
> Jason
>> into.
>> Thomas
Jason Weathersby
BIRT Exchange
Re: Decreasing image quality in PDF-Export [message #882269 is a reply to message #882125] Wed, 06 June 2012 02:48 Go to previous messageGo to next message
Thanks for the hints. I have set the image width. So I have a look into the links and try again.
Re: Decreasing image quality in PDF-Export [message #882306 is a reply to message #882269] Wed, 06 June 2012 04:15 Go to previous messageGo to next message
I read the document and tried a couple of things.
In the viewer the image remains at the large scale and is cut at the end of the container (only width is defined, the hight should be automatic according to the proportional value of the image).
In the PDF the image has the right dimensions 5 cm wide, but the resolution remains the same.
I tried:
Image:
- Proportional scale: true/false
- Fit to container: true/false
- width: blanc (setting the width is showing the image in the right size but the resolution is too high; according to your link the width should be empty)
Container (Grid):
- Can shrink: true/false
- width 5 cm
- hight (3 in) => no effect.
- Display: Block / Inline
Container (Column of grid):
- width: 5 cm / 40 mm / 3 in / blanc
Container (Row of grid):
- hight: 4 in => image is cut at 4in, not scaled in the viewer.
Report:
- Image DPI: 0 / 96 / 120
Thanks for your help.
Thomas
Re: Decreasing image quality in PDF-Export [message #882654 is a reply to message #882306] Wed, 06 June 2012 19:29 Go to previous messageGo to next message
Thomas,
I was able to get the image to scale down but the pdf size had very
little difference. Take a look at the attached example. Change the dpi
to something like 300 and then back to 96.
Jason
> I tried:
> Image: - Proportional scale: true/false
> be empty)
> Container (Grid): - Can shrink: true/false
> - width 5 cm - hight (3 in) => no effect.
> Container (Column of grid): - Can shrink: true/false
> Container (Row of grid): - hight: 4 in => image is cut at 4in, not
> Report:
> Thomas
  • Attachment: ImageDPI.zip
    (Size: 9.77KB, Downloaded 39 times)
Jason Weathersby
BIRT Exchange
Re: Decreasing image quality in PDF-Export [message #884721 is a reply to message #882654] Mon, 11 June 2012 13:14 Go to previous messageGo to next message
Hi Jason,
thank you very much for your efforts.
I tried your example and experimented with an own image (higher resolution) but had no success. The variation of the filesize went away when I deleted the footer in the master page (date, time).
I succeeded in keeping the image size the same, but I had no success reducing the image resolution (in the PDF).
As workaround I will have two directories of the images. One with 96 dpi and the other with 300 dpi. According to a parameter setting BIRT will fetch the images from one of those directories.
Thomas
Re: Decreasing image quality in PDF-Export [message #884729 is a reply to message #884721] Mon, 11 June 2012 13:27 Go to previous messageGo to next message
Thomas,
Thanks for the update. Any chance you could log a bugzilla entry to
improve the behavior?
Jason
On 6/11/2012 1:14 PM, Thomas Thym wrote:
> Hi Jason,
> thank you very much for your efforts. I tried your example and
> Thomas
Jason Weathersby
BIRT Exchange
Re: Decreasing image quality in PDF-Export [message #885122 is a reply to message #884729] Tue, 12 June 2012 09:52 Go to previous messageGo to next message
Jason,
I filed a bug report: Bug 382371
bugs.eclipse.org/bugs/show_bug.cgi?id=382371
Thomas
Re: Decreasing image quality in PDF-Export [message #885183 is a reply to message #885122] Tue, 12 June 2012 11:04 Go to previous message
Thomas
Thanks for logging this.
Jason
On 6/12/2012 9:52 AM, Thomas Thym wrote:
> Jason,
> Thomas
Jason Weathersby
BIRT Exchange
Previous Topic:org.eclipse.birt.core.archive.FolderArchive Example?
Next Topic:Missing pre-defined styles for grid-row, grid-cell, table-row, table-cell
Current Time: Wed May 22 04:19:42 EDT 2013
Powered by FUDForum. Page generated in 0.09721 seconds
