Home » Eclipse Projects » XML Schema Definition (XSD) » Inline embedded Schema(Inline embedded Schema)
Inline embedded Schema [message #881252] Mon, 04 June 2012 04:20 Go to next message
Sasi Varnan Sundarakandasamy is currently offline Sasi Varnan Sundarakandasamy
How can I load an inline embedded schema as XSDSchema?
I have a model which can have any contents inside. Similar to the WSDL types, I want to inline the schema definitions there. If I declare a schema in it, I want the EMFResource to load it as XSDSchema element. Currently all my elements are loaded as XSDAnyType elements.
Please suggest.
Re: Inline embedded Schema [message #881320 is a reply to message #881252] Mon, 04 June 2012 06:30 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Sasi,
Comments below.
What's it embedded in?
The best you can do is use XSDResourceImpl to load the whole resource;
it will scan the DOM for xsd:schema elements and build XSDSchema
instances from them. The XSD model needs be built from a DOM; the SAX
parsing used by XMLResourceImpl/XMIResourceImpl won't suffice.
> Please suggest.
Re: Inline embedded Schema [message #881836 is a reply to message #881320] Tue, 05 June 2012 06:45 Go to previous messageGo to next message
Hi Ed,
Thanks for the input. I tried loading my file with the XSDResourceImpl and called the getSchema, but i am getting some exception logged in the cosole. Sample content attached
I am gtting the following error
org.eclipse.emf.common.util.BasicEList$BasicIndexOutOfBoundsException: index=0, size=0
at org.eclipse.emf.common.util.BasicEList.get(BasicEList.java:352)
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java:1576)
at org.eclipse.xsd.impl.XSDSchemaImpl.traverseToRootForPatching(XSDSchemaImpl.java:1529)
at org.eclipse.xsd.impl.XSDConcreteComponentImpl.changeAttribute(XSDConcreteComponentImpl.java:1183)
at org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchemaImpl.java:2467)
at org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDConcreteComponentImpl.java:1154)
at org.eclipse.xsd.impl.XSDConcreteComponentImpl.setElementGen(XSDConcreteComponentImpl.java:2791)
at org.eclipse.xsd.impl.XSDConcreteComponentImpl.setElement(XSDConcreteComponentImpl.java:2822)
at org.eclipse.xsd.impl.XSDSchemaImpl.setElement(XSDSchemaImpl.java:2601)
at org.eclipse.xsd.impl.XSDSchemaImpl.createMetaSchema(XSDSchemaImpl.java:538)
at org.eclipse.xsd.util.XSDResourceImpl.handleSchemaElement(XSDResourceImpl.java:833)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl.java:702)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl.java:796)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaForSchema(XSDSchemaImpl.java:665)
at org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl.handleNewBaseTypeDefinition(XSDSimpleTypeDefinitionImpl.java:1677)
at org.eclipse.xsd.impl.XSDSimpleTypeDefinitionImpl.reconcileAttributes(XSDSimpleTypeDefinitionImpl.java:1625)
  • Attachment: types.xml
    (Size: 0.71KB, Downloaded 43 times)
Re: Inline embedded Schema [message #881896 is a reply to message #881836] Tue, 05 June 2012 08:56 Go to previous messageGo to next message
What version of XSD are you using? Maybe you want to try with the
namespace used in the final 1.0 specification.
http://www.w3.org/2001/XMLSchema
On 05/06/2012 12:45 PM, Sasi Varnan Sundarakandasamy wrote:
> Hi Ed,
Re: Inline embedded Schema [message #881963 is a reply to message #881896] Tue, 05 June 2012 10:53 Go to previous message
Hi Ed,
The change of namespace worked. Thanks again.
Thanks & Regards
Sasi Varnan
Previous Topic:Include several XSD files
Next Topic:Defining type for specific Occrrance of the element.
Current Time: Sat May 18 22:53:14 EDT 2013
Powered by FUDForum. Page generated in 0.01701 seconds
