Home » Modeling » ATL » How to create java objects than creating xmi output in ATL transformation?
| How to create java objects than creating xmi output in ATL transformation? [message #880035] |
Fri, 01 June 2012 06:12  |
Kosala Yapa Messages: 133 Registered: September 2010 |
Hi there,
The following java program creates an xmi output file called tpfOut.xmi. I am just wondering, if someone can give me a clue how to create/capture java objects instead of xmi output?
The program is:
package org.eclipse.m2m.atl.launch.files;
import java.io.IOException;
import java.io.InputStream;
import java.net.URL;
import java.util.HashMap;
import java.util.Map;
import java.util.Properties;
import java.util.Map.Entry;
import org.eclipse.core.runtime.FileLocator;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.core.runtime.NullProgressMonitor;
import org.eclipse.core.runtime.Path;
import org.eclipse.core.runtime.Platform;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.xmi.impl.EcoreResourceFactoryImpl;
import org.eclipse.m2m.atl.common.ATLExecutionException;
import org.eclipse.m2m.atl.core.ATLCoreException;
import org.eclipse.m2m.atl.core.IExtractor;
import org.eclipse.m2m.atl.core.IInjector;
import org.eclipse.m2m.atl.core.IModel;
import org.eclipse.m2m.atl.core.IReferenceModel;
import org.eclipse.m2m.atl.core.ModelFactory;
import org.eclipse.m2m.atl.core.emf.EMFExtractor;
import org.eclipse.m2m.atl.core.emf.EMFInjector;
import org.eclipse.m2m.atl.core.emf.EMFModelFactory;
import org.eclipse.m2m.atl.core.launch.ILauncher;
import org.eclipse.m2m.atl.engine.emfvm.launch.EMFVMLauncher;
* Entry point of the 'Tpf3' transformation module.
public class Tpf3 {
* The property file. Stores module list, the metamodel and library locations.
* @generated
private Properties properties;
* The IN model.
* @generated
protected IModel inModel;
* The OUT model.
* @generated
protected IModel outModel;
* The main method.
* @param args
* are the arguments
* @generated
try {
// if (args.length < 2) {
// System.out.println("Arguments not valid : {IN_model_path, OUT_model_path}.");
//} else {
Tpf3 runner = new Tpf3();
//runner.loadModels(args[0]);
runner.loadModels("tpfIN.xmi");
runner.doTpf3(new NullProgressMonitor());
//runner.saveModels(args[1]);
runner.saveModels("tpfOut.xmi");
} catch (ATLCoreException e) {
e.printStackTrace();
} catch (IOException e) {
} catch (ATLExecutionException e) {
* Constructor.
* @generated
public Tpf3() throws IOException {
properties = new Properties();
properties.load(getFileURL("Tpf3.properties").openStream());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
//System.out.println(properties);
* Load the input and input/output models, initialize output models.
* @param inModelPath
* the IN model path
* @throws ATLCoreException
* if a problem occurs while loading models
* @generated
public void loadModels(String inModelPath) throws ATLCoreException {
ModelFactory factory = new EMFModelFactory();
IInjector injector = new EMFInjector();
IReferenceModel sourceMetamodel = factory.newReferenceModel();
injector.inject(sourceMetamodel, getMetamodelUri("source"));
IReferenceModel targetMetamodel = factory.newReferenceModel();
injector.inject(targetMetamodel, getMetamodelUri("target"));
this.inModel = factory.newModel(sourceMetamodel);
injector.inject(inModel, inModelPath);
this.outModel = factory.newModel(targetMetamodel);
* Save the output and input/output models.
* @param outModelPath
* the OUT model path
* if a problem occurs while saving models
* @generated
public void saveModels(String outModelPath) throws ATLCoreException {
IExtractor extractor = new EMFExtractor();
extractor.extract(outModel, outModelPath);
* Transform the models.
* @param monitor
* the progress monitor
* if an error occurs during models handling
* @throws IOException
* if a module cannot be read
* @throws ATLExecutionException
* if an error occurs during the execution
* @generated
public Object doTpf3(IProgressMonitor monitor) throws ATLCoreException, IOException, ATLExecutionException {
ILauncher launcher = new EMFVMLauncher();
Map<String, Object> launcherOptions = getOptions();
launcher.initialize(launcherOptions);
launcher.addInModel(inModel, "IN", "source");
launcher.addOutModel(outModel, "OUT", "target");
return launcher.launch("run", monitor, launcherOptions, (Object[]) getModulesList());
* Returns an Array of the module input streams, parameterized by the
* property file.
* @return an Array of the module input streams
* @generated
protected InputStream[] getModulesList() throws IOException {
InputStream[] modules = null;
String modulesList = properties.getProperty("Tpf3.modules");
if (modulesList != null) {
String[] moduleNames = modulesList.split(",");
modules = new InputStream[moduleNames.length];
for (int i = 0; i < moduleNames.length; i++) {
String asmModulePath = new Path(moduleNames[i].trim()).removeFileExtension().addFileExtension("asm").toString();
modules[i] = getFileURL(asmModulePath).openStream();
return modules;
* Returns the URI of the given metamodel, parameterized from the property file.
* @param metamodelName
* the metamodel name
* @return the metamodel URI
* @generated
protected String getMetamodelUri(String metamodelName) {
return properties.getProperty("Tpf3.metamodels." + metamodelName);
* Returns the file name of the given library, parameterized from the property file.
* @param libraryName
* the library name
* @return the library file name
* @generated
protected InputStream getLibraryAsStream(String libraryName) throws IOException {
return getFileURL(properties.getProperty("Tpf3.libraries." + libraryName)).openStream();
* Returns the options map, parameterized from the property file.
* @return the options map
* @generated
protected Map<String, Object> getOptions() {
Map<String, Object> options = new HashMap<String, Object>();
for (Entry<Object, Object> entry : properties.entrySet()) {
if (entry.getKey().toString().startsWith("Tpf3.options.")) {
options.put(entry.getKey().toString().replaceFirst("Tpf3.options.", ""),
entry.getValue().toString());
return options;
* Finds the file in the plug-in. Returns the file URL.
* @param fileName
* the file name
* @return the file URL
* if the file doesn't exist
* @generated
protected static URL getFileURL(String fileName) throws IOException {
final URL fileURL;
if (isEclipseRunning()) {
URL resourceURL = Tpf3.class.getResource(fileName);
if (resourceURL != null) {
fileURL = FileLocator.toFileURL(resourceURL);
} else {
fileURL = null;
} else {
fileURL = Tpf3.class.getResource(fileName);
if (fileURL == null) {
throw new IOException("'" + fileName + "' not found");
} else {
return fileURL;
* Tests if eclipse is running.
* @return <code>true</code> if eclipse is running
* @generated
public static boolean isEclipseRunning() {
try {
return Platform.isRunning();
} catch (Throwable exception) {
// Assume that we aren't running.
return false;
Thanks in advance.
Kosala
| Re: How to create java objects than creating xmi output in ATL transformation? [message #880044 is a reply to message #880035] |
Fri, 01 June 2012 06:26   |
Ed Willink Messages: 3180 Registered: July 2009 |
Look at saveModels
Ed Willink
On 01/06/2012 11:12, Kosala Yapa wrote:
> Hi there,
> The program is:
> public class Tpf3 {
> library locations.
> * @generated
> * The IN model.
> * @generated
> * The OUT model.
> * @generated
> * The main method.
> * * @param args
> * are the arguments
> * @generated
> public static void main(String[] args) {
> try {
> //} else {
> * Constructor.
> * @generated
> * * @param inModelPath
> * the IN model path
> * @generated
> * * @param outModelPath
> * @generated
> * * @param monitor
> * @generated
> * property file.
> * * @return an Array of the module input streams
> * @generated */
> return modules;
> property file.
> * * @param metamodelName
> * @generated
> metamodelName);
> the property file.
> * * @param libraryName
> * the library name
> * @generated
> * * @return the options map
> * @generated
> ""), entry.getValue().toString());
> return options;
> * * @param fileName
> * the file name
> * * @generated
> final URL fileURL;
> } else {
> fileURL = null;
> } else {
> } else {
> return fileURL;
> * * @return <code>true</code> if eclipse is running
> * @generated
> try {
> return false;
> Thanks in advance.
> Kosala
| Re: How to create java objects than creating xmi output in ATL transformation? [message #881839 is a reply to message #880044] |
Tue, 05 June 2012 06:46  |
Hi there,
//outModelPath location of xmi output
class EMFExtractor: The EMF implementation of the IExtractor interface.
Problem:
It looks to me that extract() method in EMFExtractor can be used to read xmi input into xmi output. Is there any way to create java objects in memory instead of xmi output?
I really appriciate any help.
Thanks in advance !
Current Time: Fri May 24 09:28:54 EDT 2013
Powered by FUDForum. Page generated in 0.01667 seconds
