Home » Modeling » EMF » suppress documentation
suppress documentation [message #881815] Tue, 05 June 2012 05:46 Go to next message
Martin Taal is currently offline Martin Taal
I am generating EMF code from an xsd (eclipselink orm) which contains invalid documentation. Meaning if the
documentation from the xsd is included in the java code I get compile errors.
Is there a way to suppress documentation generation in the java code? Or to prevent it being transferred from the xsd to
the ecore model?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: suppress documentation [message #881893 is a reply to message #881815] Tue, 05 June 2012 08:51 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Martin,
No, there's no way to exclude that. What does it look like?
On 05/06/2012 11:46 AM, Martin Taal wrote:
> invalid documentation. Meaning if the documentation from the xsd is
> Or to prevent it being transferred from the xsd to the ecore model?
Re: suppress documentation [message #881905 is a reply to message #881893] Tue, 05 June 2012 09:18 Go to previous messageGo to next message
The documentation in the xsd contains javadoc start and end tags (/* and */) so these are placed in the javadoc
resulting in an early end of the comment.
gr. Martin
On 06/05/2012 02:51 PM, Ed Merks wrote:
> Martin,
>> to the ecore model?
The Netherlands
Re: suppress documentation [message #881928 is a reply to message #881905] Tue, 05 June 2012 10:05 Go to previous message
Martin,
We should probably handle that someone in the conversion process or in
the generator...
> gr. Martin
>> Martin,
>>> Hi,
>>> compile errors.
>>> to the ecore model?
Previous Topic:[TENEO] Multiple inheritance, MappedSuperclass+SINGLE_TABLE
Next Topic:[CDO 4.1] : Adapter of ResourceSet of remote user not notified on Resource add/remove
Current Time: Tue May 21 15:16:47 EDT 2013
Powered by FUDForum. Page generated in 0.01819 seconds
