Home » Eclipse Projects » Plugin Development Environment (PDE) » Run eclipse quickfix on a java source code using java program(Run eclipse quickfix on a java source code using java program)
Run eclipse quickfix on a java source code using java program [message #881528] Mon, 04 June 2012 15:02 Go to next message
Sharad Jain is currently offline Sharad Jain
Hello All,
I need to know if there exists a way wherein I can force the eclipse quickfix on a java code.
I am trying to convert a c sharp library to a java library, however when I see the output, I see that there are many quick fixes available, and I need to go to manually to all quickfixes, to sort the issues in my code.
However, I would like to know if there exists a way which allows me to fix all these errors using eclipse API.
Any discussion on this greatly appreciated.
Fardu
Re: Run eclipse quickfix on a java source code using java program [message #881589 is a reply to message #881528] Mon, 04 June 2012 17:58 Go to previous message
Also, recently I encountered Class 'ValidationMarkerResolution' in org.eclipse.emf, but I am not so sure, that is this class is actually the same what I require for my purpose.
[Updated on: Mon, 04 June 2012 19:46]
Report message to a moderator
Previous Topic:Server and JDK Validation
Next Topic:OutlineView
Current Time: Mon May 20 04:14:57 EDT 2013
Powered by FUDForum. Page generated in 0.01566 seconds
