Home » Modeling » EMF » [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.internal.c
[CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.internal.c [message #878473] Tue, 29 May 2012 07:43 Go to next message
Erdal Karaca is currently offline Erdal Karaca
Getting this exception after fetching the sources from git (using master branch):
org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl
	at org.hibernate.internal.SessionFactoryImpl.getEntityPersister(SessionFactoryImpl.java:1190)
	at org.hibernate.type.EntityType.toLoggableString(EntityType.java:494)
	at org.hibernate.type.AnyType.toLoggableString(AnyType.java:201)
	at org.hibernate.type.CollectionType.renderLoggableString(CollectionType.java:193)
	at org.hibernate.type.CollectionType.toLoggableString(CollectionType.java:184)
	at org.hibernate.internal.util.EntityPrinter.toString(EntityPrinter.java:79)
	at org.hibernate.internal.util.EntityPrinter.toString(EntityPrinter.java:121)
	at org.hibernate.event.internal.AbstractFlushingEventListener.logFlushResults(AbstractFlushingEventListener.java:131)
	at org.hibernate.event.internal.AbstractFlushingEventListener.flushEverythingToExecutions(AbstractFlushingEventListener.java:107)
	at org.hibernate.event.internal.DefaultFlushEventListener.onFlush(DefaultFlushEventListener.java:51)
	at org.hibernate.internal.SessionImpl.flush(SessionImpl.java:1127)
	at org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.doWrite(HibernateStoreAccessor.java:688)
	at org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:149)
	at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:487)
	at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:43)
	at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
	at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:262)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:96)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
	at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:84)
	at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:90)
	at org.eclipse.net4j.signal.Signal.doInput(Signal.java:326)
	at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:63)
	at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:63)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:251)
	at org.eclipse.net4j.signal.Signal.run(Signal.java:147)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
P.S.: I updated to the latest TENEO/Hibernate (4.1)
[Updated on: Tue, 29 May 2012 07:43]
Report message to a moderator
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #878533 is a reply to message #878473] Tue, 29 May 2012 09:38 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Erdal,
When do you get this exception? With one of the example projects?
gr. Martin
> at
> at
> at
> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #879641 is a reply to message #878533] Thu, 31 May 2012 11:13 Go to previous messageGo to next message
No, I switched to git master and restarted the application and I am getting that exception. When switching back to 4.0 everything works.
It seems there are some incompatible changes applied to the master in the past two weeks... I will investigate on this and hopefully give more details...
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #879674 is a reply to message #879641] Thu, 31 May 2012 12:03 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
Am 31.05.2012 17:13, schrieb Erdal Karaca:
> everything works.
Could this be caused by some mostly internal changes I recently applied to BaseCDORevision.java?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881228 is a reply to message #879674] Mon, 04 June 2012 03:23 Go to previous messageGo to next message
I checked BaseCDORevision.java, nothing suspect...
Maybe, it is a hibernate 4 issue:
I am getting a lot of "HHH000262" error messages when starting the server. This was not the case with 4.0 (or hibernate 3.6)
Found this post:
https://play.lighthouseapp.com/projects/57987/tickets/1509-125-error-in-log-when-starting-application
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881235 is a reply to message #881228] Mon, 04 June 2012 03:41 Go to previous messageGo to next message
These are the warning/info messages when running cdo 4.1:
main [debug] Updating db schema for Hibernate PackageHandler
2012-06-04 08:59:41.473 INFO  [main     ] (DatabaseMetadata.java:120)  - HHH000262: Table not found: cdo_package_info
2012-06-04 08:59:41.479 INFO  [main     ] (DatabaseMetadata.java:120)  - HHH000262: Table not found: cdo_package_unit
2012-06-04 08:59:41.482 INFO  [main     ] (DatabaseMetadata.java:120)  - HHH000262: Table not found: cdo_system_information
2012-06-04 08:59:41.485 INFO  [main     ] (DatabaseMetadata.java:120)  - HHH000262: Table not found: cdo_system_property
2012-06-04 08:59:41.487 INFO  [main     ] (DatabaseMetadata.java:120)  - HHH000262: Table not found: cdo_package_info
2012-06-04 08:59:41.490 INFO  [main     ] (DatabaseMetadata.java:120)  - HHH000262: Table not found: cdo_package_unit
2012-06-04 08:59:41.491 INFO  [main     ] (DatabaseMetadata.java:120)  - HHH000262: Table not found: cdo_system_information
2012-06-04 08:59:41.493 INFO  [main     ] (DatabaseMetadata.java:120)  - HHH000262: Table not found: cdo_system_property
The tables are generated, though...
As mentioned in the previous post, there is a user havin similar problems with hibernate: https://play.lighthouseapp.com/projects/57987/tickets/1509-125-error-in-log-when-starting-application
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881238 is a reply to message #881228] Mon, 04 June 2012 03:43 Go to previous messageGo to next message
Hi Erdal,
Yes could be related, do these entries say something about the reason why table creation fails? Note that Hibernate will
start fine even if the database schema update fails, the logs shows more information hopefully.
gr. Martin
> 3.6)
> Found this post:
The Netherlands
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881242 is a reply to message #881235] Mon, 04 June 2012 03:52 Go to previous messageGo to next message
Can it be a casing issue? That the table names in the database are uppercased or lowercased, depends also if you run on
windows (which is/was case insensitive afair) or linux
gr. Martin
The Netherlands
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881267 is a reply to message #881242] Mon, 04 June 2012 04:55 Go to previous messageGo to next message
Not sure if this is an issue with case in/sensitivity as it just works with the same configuration in 4.0 on the same amchine...
How do you package the hibernate jars. Is it too much overhead to generate a new org.hibernate bundle with the latest jars (4.1.4)?
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881277 is a reply to message #881267] Mon, 04 June 2012 05:11 Go to previous messageGo to next message
It takes me an hour or so to repackage hibernate. But why, do you think that it will solve this issue?
Can you debug into the HibernatePackageHandler.readPackageUnits method, when starting the server?
Really strange that it can't find these tables but does not seem to fail there..
gr. Martin
> amchine...
> jars (4.1.4)?
The Netherlands
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881288 is a reply to message #881277] Mon, 04 June 2012 05:38 Go to previous messageGo to next message
Do you know whether using jTDS (currently, version 1.2.5) to connect to the MS SQL Server is supported with hibernate 4.1? You are packaging the com.microsoft.sqlserver.jdbc bundle to be used.
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881294 is a reply to message #881288] Mon, 04 June 2012 05:43 Go to previous messageGo to next message
I have no idea, never tried it, but my guess/assumption would be that it should work fine.
gr. Martin
The Netherlands
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881314 is a reply to message #881294] Mon, 04 June 2012 06:25 Go to previous messageGo to next message
Tried both jtds and mssql jdbc driver... no luck...
First, there are a lot of INFO messages "HHH000262: Table not found: ...", then follow ERROR messages: "HHH000388: Unsuccessful: create table ...": saying the boolean data type for column, parameter or variable with nr. ... could not be found...
The INFO message HHH000262 are printed out for the cdo epackages as well, but no ERROR messages follow and hibernate creates the cdo tables successfully.
Not sure where to look at.
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881316 is a reply to message #881314] Mon, 04 June 2012 06:31 Go to previous messageGo to next message
Just found a message from another user of Teneo who tries to use Teneo 2.0, seems to be the same problem...
http://www.eclipse.org/forums/index.php/mv/msg/358568/881299/
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881321 is a reply to message #881316] Mon, 04 June 2012 06:36 Go to previous messageGo to next message
Yes I saw it to, seems very much related. Which databases are you testing on? And which dialect are you using?
gr. Martin
The Netherlands
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881324 is a reply to message #881321] Mon, 04 June 2012 06:41 Go to previous messageGo to next message
Dialect: org.hibernate.dialect.SQLServerDialect
MSSQLServer: 10.0.1600.22
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881331 is a reply to message #881324] Mon, 04 June 2012 06:54 Go to previous messageGo to next message
Hi Erdal,
It seems to be this issue:
https://hibernate.onjira.com/browse/HHH-6420
Can you switch to this dialect:
org.hibernate.dialect.SQLServer2008Dialect
gr. Martin
The Netherlands
Re: [CDO/Hibernate/Teneo] org.hibernate.MappingException: Unknown entity: org.eclipse.emf.cdo.intern [message #881333 is a reply to message #881331] Mon, 04 June 2012 06:59 Go to previous message
Thanks, that fixed it!
Previous Topic:Saving loaded contents to another file add cross document references
Next Topic:[TENEO] Multiple inheritance, MappedSuperclass+SINGLE_TABLE
Current Time: Sun May 19 16:21:59 EDT 2013
Powered by FUDForum. Page generated in 0.02313 seconds
