Home » Eclipse Projects » Virgo » Spring Configurable across multitple bundles
Spring Configurable across multitple bundles [message #881261] Mon, 04 June 2012 04:43 Go to next message
Carlos Salinas is currently offline Carlos Salinas
Member
Hello community,
I am in a nightmare trying to using Configuble object inside multiples bundle, i am not sure after mani intentsif Virgo already supports this functionality, because i found these tickets:
https://issuetracker.springsource.com/browse/DMS-2490?page=com.atlassian.streams.streams-jira-plugin:activity-stream-issue-tab#issue-tabs
https://jira.springsource.org/browse/SPR-5156
Are they resolved? And if is Yes the answer, how can i configure virgo to commit it?
Re: Spring Configurable across multitple bundles [message #882311 is a reply to message #881261] Wed, 06 June 2012 04:26 Go to previous messageGo to next message
Member
I tested the problem having two bundles. The first one is a Web bundle that consumes a service registered by the second jar bundle.
When the web bundle invokes a method in the service api, this invokation produces the creation of @Configurable objects in the method's implementation, having this annotated objects spring dependencies to be injected by IoC. BUT the creation ALWAYS produces an Spring exception, because the Jar Bundle's ApplicationContext cannot find those bean definitions.
BUT IF i put the bean definitions in Web Bundle Spring descriptors, needed to create those Configurable Objects inside the Jar Bundle. Then they are injected.
My doubt is: How Can an @Configurable Object look up its bean dependecies in another ApplicationContext diferent than it belongs to?
Thanks u.
Re: Spring Configurable across multitple bundles [message #882898 is a reply to message #882311] Thu, 07 June 2012 08:36 Go to previous message
Frieder Heugel is currently offline Frieder Heugel
Member
Hi all
I might be wrong but isn't the new weaving hook [1] able to add package imports to a bundle?
Frieder
[1] http://www.slideshare.net/mfrancis/bytecode-weaving-in-osgi-enhance-your-classes-not-your-dependency-graph-tim-ward
Previous Topic:Virgo Tooling M4 Released
Next Topic:OSGi case study
Current Time: Fri May 24 02:38:55 EDT 2013
Powered by FUDForum. Page generated in 0.07043 seconds
