Home » Eclipse Projects » Eclipse Platform » Invalid preference page path: XML Syntax(Android with Eclipse)
Invalid preference page path: XML Syntax [message #691862] Sat, 02 July 2011 12:21 Go to next message
Simon  is currently offline Simon
Hello everyone,
Could somebody response me why I got wrong in Eclipse 3.7 when I using JRE 6_26 with Android ADT_11?
I can't look up solution that I can solve this problem.
There was error log in Eclipse when I start it that showed "Invalid preference page path: XML Syntax" thus I can't compile my code in Android.
thanks!
Re: Invalid preference page path: XML Syntax [message #695242 is a reply to message #691862] Mon, 11 July 2011 07:09 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
On 02.07.2011 18:21, Simon wrote:
> Hello everyone,
> Android.
Looks like a problem with Android tooling and not Eclipse itself.
Dani
> thanks!
Re: Invalid preference page path: XML Syntax [message #881049 is a reply to message #691862] Sun, 03 June 2012 15:17 Go to previous message
Brian Canin is currently offline Brian Canin
Had this problem, I see multiple questions unanswered on this topic:
MESSAGE Invalid preference page path: XML Syntax
Easy fix....
I was able to fix it by creating a new workspace and then importing my project into it. If you had an original installation of Eclipse, then downloaded a new eclipse, readded all your android, ect. into it, you might get this error. Probably has to do with the XML with different keys from the old version in your hidden files in your workspace!
Previous Topic:Reuse the same menu contributions at multiple places
Next Topic:installed feature are not visible
Current Time: Fri May 24 16:29:15 EDT 2013
Powered by FUDForum. Page generated in 0.02705 seconds
