Home » Modeling » Modeling (top-level project) » uml2code(where is the uml2 metamodel)
uml2code [message #880636] Sat, 02 June 2012 10:11 Go to next message
franz gregor is currently offline franz gregor
hi,
i'm want to learn how to use the eclipse modeling framework and therfore decided to build a uml2 to code (python) generator.
As far as i understand the field i need the metamodel of the uml2(tools), a user specific model, a workflow and a template to do this.
I'm already failing at the first step... where do i find the uml2 metamodel? I found org.eclipse.uml2.uml.resources and in there is a package metamodels, but i can't create a ecore diagram of them and theire filetype is .uml. So i'm not sure whether they're the right ones.
franz
[Updated on: Sat, 02 June 2012 10:13]
Report message to a moderator
Re: uml2code [message #880649 is a reply to message #880636] Sat, 02 June 2012 11:03 Go to previous message
Ed Merks is currently offline Ed Merks
Franz,
To learn how to use UML2 you can start with the links in the wiki:
http://wiki.eclipse.org/MDT-UML2
There are several choices for template languages. Xtend
(http://www.eclipse.org/xtend/) and Acceleo
(http://www.eclipse.org/acceleo/) are quite well supported.
On 02/06/2012 4:11 PM, franz gregor wrote:
> hi,
> Best regards,
> franz
Previous Topic:modeling contructs to be intuitive
Next Topic:Visual Editor
Current Time: Tue May 28 15:43:58 EDT 2013
Powered by FUDForum. Page generated in 0.01625 seconds
