Home » Modeling » UML2 » UML2 4.0 Migration Guide(UML2 4.0 Migration Guide release plans)
UML2 4.0 Migration Guide [message #880141] Fri, 01 June 2012 10:08 Go to next message
Felix Sulima is currently offline Felix Sulima
Dear UML2 component developers.
To align the dependent products with UML2 Release 4.0 we expect the corresponding Migration Guide to be published (by analogy with migration guides to previous versions wiki.eclipse.org/MDT-UML2#Guides).
May you please share your plans about when it's going to be done so we could make up our schedule.
May be some early access version of the guide can be made available?
Re: UML2 4.0 Migration Guide [message #880160 is a reply to message #880141] Fri, 01 June 2012 10:38 Go to previous message
If you do a Wiki search you can find
http://wiki.eclipse.org/MDT/UML2/UML2_4.0_Migration_Guide.
Quite a few problems have been resolved in conjunction with OCL usage so
what I found was:
For simple UML in plugins it just works. You might just notice that the
PrimitiveTypes now have their own package.
When running standalone there is at last a UMLResourcesUtil.init() that
makes initialisation 'easy'. Make sure you call it; you'll really
struggle to replicate it, and you'll struggle again when UML 2.5 comes
along.
If you're using complex UML, you may want to consult the UML 2.4.1 specs
directly as well.
Ed Willink
Previous Topic: .UML to .XML
Next Topic:XML and JDOM
Current Time: Fri May 24 03:35:48 EDT 2013
Powered by FUDForum. Page generated in 0.01633 seconds
