Home » Eclipse Projects » Memory Analyzer » Some Paths to GC root not found?(Some Paths to GC root not found?)
Some Paths to GC root not found? [message #878367] Tue, 29 May 2012 02:48 Go to next message
Xavier Appe is currently offline Xavier Appe
When using MAT 1.1.1 with Eclipse, I encountered the following problem:
One of the GC root reference is not found when clicking on
www.pics-web.com/images/gcroot1.png
(This forum does not allow me to insert image until I creates 25 messages)
I get
www.pics-web.com/images/gcroot2.png
But the reference to the firstTimer is not mentionned!
www.pics-web.com/images/gcroot3.png
Is this a bug or am I doing something wrong?
Thank you
Xavier Appe
Re: Some Paths to GC root not found? [message #878976 is a reply to message #878367] Wed, 30 May 2012 05:45 Go to previous messageGo to next message
Andrew Johnson is currently offline Andrew Johnson
Member
The images again:
http://www.pics-web.com/images/gcroot1.png
>I get
http://www.pics-web.com/images/gcroot2.png
http://www.pics-web.com/images/gcroot3.png
Did you click on 'Fetch Next Paths'?
There is a similar bug report Bugzilla 371642: Path To GC Roots gives incomplete information where it appears that the query only shows the shortest paths. For example if A>B>C and A>C then it won't show the path to roots from C back to B.
Does the explanation in the bug help?
Re: Some Paths to GC root not found? [message #879356 is a reply to message #878976] Wed, 30 May 2012 23:33 Go to previous message
Hi Andrew,
Thank you for your answer.
I clicked on 'Fetch Next Paths' until no more paths left (see below)
www.pics-web.com/images/gcroot4.png
I couldn't find the reference to firstTimer but it really looks like the bug mentionned above: 371642.
It looks like we have DealNotifyTable->...->firstTimer->...->AppContext and DealNotifyTable->...->AppContext
www.pics-web.com/images/gcroot5.png
Hope we can have a fix soon, because otherwise it is very useful tool!
Xavier Appe
[Updated on: Wed, 30 May 2012 23:34]
Report message to a moderator
Previous Topic:java.lang.NoClassDefFoundError: org/eclipse/mat/ui/snapshot/editor/ISnapshotEditorInput
Next Topic:No way to run the MAT
Current Time: Sat May 25 13:04:49 EDT 2013
Powered by FUDForum. Page generated in 0.06229 seconds
