Home » Eclipse Projects » BIRT » Build DataSource from code - without external resources?
Build DataSource from code - without external resources? [message #759066] Fri, 25 November 2011 16:53 Go to next message
Anton is currently offline Anton
I would like to build a datasource from code that does not have any
reference to any external resources on the filesystem, eg. flatfile,
xmlfile, database etc.
As an example a xml datasource can be build like this:
OdaDataSourceHandle dataSourceHandle =
elementFactory.newOdaDataSource(dataSourceName,
org.eclipse.birt.report.data.oda.xml");
dataSourceHandle.setProperty("FILELIST", dataSourceFile);
But how do I build a datasource as a pojo without any reference to external
resources? I have tried:
ElementFactory elementFactory = report.getElementFactory();
elementFactory.newOdaDataSource(dataSourceName);
but how do I populate it with some content that I can next connect a dataset
to? Maybe there are some examples showing how this can be done?
Re: Build DataSource from code - without external resources? [message #759507 is a reply to message #759066] Mon, 28 November 2011 15:22 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Are you wanting to create a scripted datasource?
Take a look at the attached example.
Jason
> external resources? I have tried:
> dataset to? Maybe there are some examples showing how this can be done?
Jason Weathersby
BIRT Exchange
Re: Build DataSource from code - without external resources? [message #878958 is a reply to message #759507] Wed, 30 May 2012 05:14 Go to previous messageGo to next message
Seton GNANHA is currently offline Seton GNANHA
Hello!
I'm a biginner with Birt and I have a same problem.
Actually i need to buid an EMF ECORE Data source from code and i cannot find any solutions.
Help me please! Jason?
Anicet
Re: Build DataSource from code - without external resources? [message #879292 is a reply to message #878958] Wed, 30 May 2012 19:24 Go to previous message
You may want to look over these threads
http://www.eclipse.org/forums/index.php/t/216203/
http://wiki.eclipse.org/Ecore_ODA_Driver#Using_the_Driver_to_Create_BIRT_Reports
http://eclipsecon.org/2011/sessions/?page=sessions&id=2028
Older post on Ecore ODA
http://timezra.blogspot.com/2008/04/oda-ecore-getting-started-guide.html
Jason
n 5/30/2012 5:14 AM, Anicet HOUNKPE wrote:
> Hello!
> find any solutions.
> Thanks Anicet
Jason Weathersby
BIRT Exchange
Previous Topic:BIRT Webservice ODA integration with JIRA
Next Topic:java.lang.Integer cannot be cast to java.lang.Long - When trying to connect to MySQL
Current Time: Wed May 22 04:13:07 EDT 2013
Powered by FUDForum. Page generated in 0.02310 seconds
