Home » Eclipse Projects » Virgo » The watched repository does not automatically picks up artifacts
The watched repository does not automatically picks up artifacts [message #878961] Wed, 30 May 2012 05:22 Go to next message
jianhui zhou is currently offline jianhui zhou
I find The watched repository does not automatically picks up artifacts.
When I copy a bundle to usr,it not automatically deployand start it.
Otherwise,I restart virgo,it works.
Why?
Re: The watched repository does not automatically picks up artifacts [message #879212 is a reply to message #878961] Wed, 30 May 2012 15:09 Go to previous messageGo to next message
Hristo Iliev is currently offline Hristo Iliev
Seems like you need the hot-deploy feature of Virgo that is provided by the pickup directory. Artifacts dropped there are automatically deployed and started.
Their dependencies are installed from Virgo's repositories.
So you tupically drop your common libraries in repository while your plan/PAR would go in pickup.
Re: The watched repository does not automatically picks up artifacts [message #879258 is a reply to message #878961] Wed, 30 May 2012 17:33 Go to previous message
Rich Mayfield is currently offline Rich Mayfield
Member
Recommend that you check out the following post (and it's thread) as it pretty nicely outlines the intent behind repositories and their passive nature - that is, bundles from a repository are deployed when needed.
http://www.eclipse.org/forums/index.php/mv/msg/172227/549403/#msg_549403
Previous Topic:Embedded system startup time
Next Topic:Some support
Current Time: Mon May 20 16:28:19 EDT 2013
Powered by FUDForum. Page generated in 0.01732 seconds
