Home » Modeling » EMF » [CDO/Teneo/Hibernate] CDO import incomplete
[CDO/Teneo/Hibernate] CDO import incomplete [message #878395] Tue, 29 May 2012 04:18 Go to next message
Matthias Casjens is currently offline Matthias Casjens
If I use the CDO import to import previously exported data into a new database the import is usually incomplete. The CDOResource objects in the database are for example missing every reference to data that is positioned after the CDOResource objects in the imported XML. Also missing are most n:m references between objects.
Changing the order of the data in the XML or importing the data twice fixes the problem, but it would be great if that wouldn't be necessary.
Shall I open a bug report for that?
Re: [CDO/Teneo/Hibernate] CDO import incomplete [message #878402 is a reply to message #878395] Tue, 29 May 2012 04:37 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
Am 29.05.2012 10:18, schrieb Matthias Casjens:
Yes please.
IIRC., the export/import support in the HibernateStore is brand new and Martin will be happy to look at it if he can
reproduce it ;-)
Cheers
/Eike
http://www.esc-net.de
Re: [CDO/Teneo/Hibernate] CDO import incomplete [message #878414 is a reply to message #878402] Tue, 29 May 2012 05:00 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Matthias,
Yes please enter a bugzilla, an example model and export xml would be great...
gr. Martin
> Yes please.
> reproduce it ;-)
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [CDO/Teneo/Hibernate] CDO import incomplete [message #878884 is a reply to message #878414] Wed, 30 May 2012 02:11 Go to previous message
Allright. I created bug 380987 for this.
[Updated on: Wed, 30 May 2012 02:24]
Report message to a moderator
Previous Topic:Generating extended EMF
Next Topic:[CDO/Teneo/Hibernate] CDO export contains multiple identical entries
Current Time: Fri May 24 06:48:55 EDT 2013
Powered by FUDForum. Page generated in 0.01596 seconds
