Home » Language IDEs » CDT » Polymorphic functions are not recognized by indexer(Polymorphic functions are not recognized by indexer)
Polymorphic functions are not recognized by indexer [message #876865] Fri, 25 May 2012 08:11 Go to next message
serafim papapanagiotou is currently offline serafim papapanagiotou
I have a base pointer initialized with a derived class
Base* ptr = new Derived();
ptr->foo(); (foo is a virtual function. Exists in both classes)
Surprisingly eclispe code navigation doesn't open the Derived class foo() function but rather the foo() from Base class.
Any suggestion how to make indexer to work for this ?
Re: Polymorphic functions are not recognized by indexer [message #877024 is a reply to message #876865] Fri, 25 May 2012 14:33 Go to previous messageGo to next message
In order to make the above more clear...Trying to do some code navigation and I select the ptr->foo() function while pressing F3 instead of going to foo() of the derived class I am going to the foo() of the basic class.
I imagine for sure somebody has encountered such an issue since this is just basic polymorphism. Any idea how to have the correct display for this ?
Re: Polymorphic functions are not recognized by indexer [message #877050 is a reply to message #877024] Fri, 25 May 2012 15:43 Go to previous messageGo to next message
Yevgeny Shifrin is currently offline Yevgeny Shifrin
I checked java behavior and it behaves as CDT. You are expecting from CDT indexer too much Smile
How would you expect it to behave in use case below?
Base* ptr = new Base();
if (condition)
ptr->foo();
Yevgeny
Re: Polymorphic functions are not recognized by indexer [message #877216 is a reply to message #877050] Sat, 26 May 2012 01:31 Go to previous messageGo to next message
All source navigators gives you the option to select which one you want to call. They don't really take you to Derived class foo() function but a prompt box is opening and they are asking you ...Derived:foo or Base:foo ?
Since this is quite basic (at least I have seen it in many IDEs) I am wondering whether this is a configuration issue in eclipse for C++
Re: Polymorphic functions are not recognized by indexer [message #877237 is a reply to message #877216] Sat, 26 May 2012 02:59 Go to previous message
Nobody Mising name is currently offline Nobody Mising name
Member
This navigation to virtual function is a lot better in CDT than in Visual Studio/Visual Assist. Just press Ctrl+T to watch the hierarchy of types that overload this virtual function.
Previous Topic:How to compile a VisualDSP project in eclipse ?
Next Topic:Can't resolve #include <stdio.h> in Windows XP Pro
Current Time: Sat May 18 11:59:41 EDT 2013
Powered by FUDForum. Page generated in 0.01952 seconds
