Home » Eclipse Projects » Gyrex » Where can I find proper documentation?
Where can I find proper documentation? [message #877062] Fri, 25 May 2012 16:18 Go to next message
Marton Sigmond is currently offline Marton Sigmond
Member
I would have a lot of question, and this is the only documentation I found:
http://wiki.eclipse.org/Gyrex/User_Guide
Is there any other doc?
Marton
Re: Where can I find proper documentation? [message #878540 is a reply to message #877062] Tue, 29 May 2012 09:50 Go to previous messageGo to next message
Peter Grube is currently offline Peter Grube
Hi Marton,
thank you for your question.
We are currently working on documentations and tutorials for gyrex.
Which area are you most interested in, development or configuration/setup?
Best regards
Peter
Re: Where can I find proper documentation? [message #885312 is a reply to message #878540] Tue, 12 June 2012 15:41 Go to previous messageGo to next message
Member
Hi Peter,
thank you for the answer.
I have many questions, from trivial to advanced ones, such as
  1. What is default user/password when ssh into the Equinox console?
  2. How should I configure two Gyrex instances so, that they find each other?
  3. How should I configure and use an external Zookeeper and disable the embedded one?
  4. Is there OSGi remote service support?
If you could answer the first two, I would really appreciate that.
I will ask the later two on separate threads though, as those are more significant ones I believe.
In general I am looking for the ideal solution for the following:
http://stackoverflow.com/questions/8667142/distributed-osgi-what-is-the-proper-way-to-manage-bundles-across-all-container
Marton
Re: Where can I find proper documentation? [message #885689 is a reply to message #885312] Wed, 13 June 2012 08:43 Go to previous messageGo to next message
Andreas Mihm is currently offline Andreas Mihm
Hi Marton,
here are some answers for your questions:
2. Setup a Gyrex cluster
in the gyrex wiki you'll find a screen cast showing, how easy it is to setup a gyrex cluster wiki.eclipse.org/Gyrex/ClusterTutorial
3. External ZooKeeper
when you want to use an external ZooKeeper for cluster coordination, you just need to connect every gyrex instance to it:
Please go to the gyrex admin ui at localhost:3110 and select the CLoud section from the left hand menu,
Below the node id you'll find the Membership information with a connect link,
please press the connect link and enter the ip address and port of your ZooKeeper Machine,
If you don't provide a port, it will use the ZooKeeper standard port 2181
On the other two questions I'll come back to you later,
I hope the answers help you out for the moment,
best regards
Andreas
Re: Where can I find proper documentation? [message #891576 is a reply to message #885312] Mon, 25 June 2012 05:33 Go to previous message
Gunnar Wagenknecht is currently offline Gunnar Wagenknecht
Hi Marton,
Am 12.06.2012 21:41, schrieb Marton Sigmond:
There is no default user/password. Currently, only key-based
authentication is available. You need to create an authorized keys file.
Any user name will do. The OSGi Console doesn't have a permission/roles
concept at the moment.
I've updated the admin guide at
http://wiki.eclipse.org/Gyrex/Administrator_Guide/Console
Andreas already posted the link to the screencast. Let me know if that
is sufficient or you need more info.
Not yet. Contributions are welcome. :)
http://bugs.eclipse.org/383415
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
http://wagenknecht.org/
Previous Topic:Gyrex 1.0 Available
Next Topic:Gyrex 1.1 Available
Current Time: Sat May 25 12:01:55 EDT 2013
Powered by FUDForum. Page generated in 0.02154 seconds
