Home » Modeling » Epsilon » ETL: protected regions not working
ETL: protected regions not working [message #877041] Fri, 25 May 2012 15:10 Go to next message
Rui Carlos  Gonçalves is currently offline Rui Carlos Gonçalves
I'm trying to use protected regions with ETL. So, I put the following code in the template:
[%=out.preserve("/*", "*/", name+"-Prop", true,"  //TODO")%]
This generates the following code:
  /* protected region Local-Prop on begin */
    //TODO
  /* protected region Local-Prop end */
which I think is correct.
Then I changed the previous code to this:
    test();
I was hopping that after generating the code again I was going to keep the 'test();', but that content is lost, and it is replaced with '//TODO'.
Am I doing anything wrong? Is there anything else I need to do, besides using the "preserve" method?
Re: ETL: protected regions not working [message #877108 is a reply to message #877041] Fri, 25 May 2012 18:18 Go to previous messageGo to next message
Horacio Hoyos is currently offline Horacio Hoyos
That seems fine according to the book. In our case we use
[%=out.startPreserve("--", "--",entity.identifier + " Additional Descriptions", true)%]
[%=out.stopPreserve()%]
But I now recall I have a report of preserved regions being overwritten as in our case. Any one has any other ideas?
Horacio Hoyos Rodriguez
EngD Student
University Of York
Re: ETL: protected regions not working [message #877685 is a reply to message #877108] Sun, 27 May 2012 07:50 Go to previous messageGo to next message
Maarten Bezemer is currently offline Maarten Bezemer
Member
I am using a similar way (and it is working for me) to generate protected regions in a Makefile:
[%= out.startPreserve("##", "", "to add additional statements", true) %]
[%= out.stopPreserve() %]
Similar ways are used for C++ source and header files.
Before I got it working correctly, I was using special' characters, like slashes
That does not work in the current Epsilon (0.9.1) release, see bug #376968.
Re: ETL: protected regions not working [message #877775 is a reply to message #877685] Sun, 27 May 2012 13:55 Go to previous messageGo to next message
I've already tried many different ways (preserve/startPreserve, different ids, different comments ), and it's not working :\
I'm not using any special character in the id.
Re: ETL: protected regions not working [message #878479 is a reply to message #877775] Tue, 29 May 2012 08:01 Go to previous messageGo to next message
Louis Rose is currently offline Louis Rose
Hi Rui Carlos,
Rui Carlos Gonçalves wrote on Sun, 27 May 2012 13:55
I'm sorry to hear that you're having problems with protected regions. I think this might be related to the bug that Martin mentions. Can you try again without the hyphen in the identifier? So, for example:
[%=out.preserve("/*", "*/", name+"Prop", true,"  //TODO")%]
I believe that, in the latest stable release of Epsilon, identifiers could only contain word characters (i.e. [a-zA-Z_0-9]). Alternatively, you can try updating to the latest interim release of Epsilon, which contains the fix for this bug and should work with your existing code.
Hope this helps,
Louis.
Re: ETL: protected regions not working [message #878567 is a reply to message #878479] Tue, 29 May 2012 10:38 Go to previous messageGo to next message
Hi Louis. Thanks for your reply.
Louis Rose wrote on Tue, 29 May 2012 13:01
No, I have already tried that...
Is there any debug mode that can me help finding the problem?
BTW, do I have to set any option in the run configuration to be able to use protected regions?
Re: ETL: protected regions not working [message #879016 is a reply to message #878567] Wed, 30 May 2012 07:23 Go to previous messageGo to next message
Hi again,
There are no additional settings that need to be enabled: protected regions should work out of the box.
It sounds as though this might be a bug. Could you produce a minimal example that I can use to reproduce this behaviour? I'll then work on fixing the issue. There's some advice on producing useful minimal examples here:
http://www.eclipse.org/epsilon/doc/articles/minimal-examples/
Louis.
Re: ETL: protected regions not working [message #886913 is a reply to message #879016] Fri, 15 June 2012 16:33 Go to previous message
I think I've solved the problem...
I was calling the template directly in a Run Configuration and it was not working.
Now I'm using "TemplateFactory.load"/"generate" methods instead of calling the template directly, and it seems to be working Smile
Not sure if this is the expected behavior, but it solved the problem.
PS: Louis, if this is still a bug (i.e., if protected regions are supposed to work even without using the "TemplateFactory.load"/"generate"), let me know, and I'll create the bug report. (I haven't done it yet, as creating a minimal example, with metamodels and editor, takes some time :\ )
[Updated on: Fri, 15 June 2012 16:34]
Report message to a moderator
Previous Topic:Building a graphical editor to compose and visualise Epsilon Workflows
Next Topic:No vaiable alternative at input 'default'
Current Time: Tue May 21 20:14:53 EDT 2013
Powered by FUDForum. Page generated in 0.02047 seconds
