Home » Modeling » Epsilon » Method 'satisfiesOne' not found for ...
Method 'satisfiesOne' not found for ... [message #876970] Fri, 25 May 2012 12:00 Go to next message
Horacio Hoyos is currently offline Horacio Hoyos
I was starting to work on some validations and from the error message it seems either I am doing something wrong, or satisfiesAll is buggy Wink. This is the code, the metamodel is Papyrus SysML.
context SysML!sysml::portandflows::FlowPort
    // The base port must be typed
    constraint IsTyped
        check : self.base_Port.type.isDefined()
	message :  "FlowPort" + self.base_Port.name + " is not typed"
    constraint IsTypedWithHiLeS
        guard : self.satisfies("IsTyped") and
		self.satisfiesOne("IsBooleanOrLogic", "IsTerminalOrNode")
	check : true
    // Logic and Boolean are not generalizations
    @lazy
    constraint IsBooleanOrLogic
	check : self.type.name = "Logic"
		or self.type.name = "Boolean"
    @lazy
    constraint HasGeneralization
	check : self.base_Port.type.generalization.isDefined()
	message :  "FlowPort" + self.base_Port.name + " type is not a generalization "
			+ "of another type (All HiLeS library types are generalizations)."
    @lazy
    constraint IsTerminalOrNode
	guard : self.satisfies("HasGeneralization")
	check : self.base_Port.type.generalization.general.name = "Terminal" or
		self.base_Port.type.generalization.general.name = "Node"
	message : "Flow Port " + self.base_Port.name + " NOT"
Horacio Hoyos Rodriguez
EngD Student
University Of York
Re: Method 'satisfiesOne' not found for ... [message #877349 is a reply to message #876970] Sat, 26 May 2012 10:19 Go to previous messageGo to next message
Antonio Garcia-Dominguez is currently offline Antonio Garcia-Dominguez
Hi Horacio,
Could you open a bug report for this, and provide us with a minimal model that reproduces the issue?
Thanks!
Re: Method 'satisfiesOne' not found for ... [message #878574 is a reply to message #877349] Tue, 29 May 2012 10:46 Go to previous message
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=380910
EngD Student
University Of York
Previous Topic:Problem using Epsilon Unit Testing Framework
Next Topic:Debugging ETL transformations
Current Time: Sun May 19 03:35:34 EDT 2013
Powered by FUDForum. Page generated in 0.02372 seconds
