Home » Modeling » UML2 » UML2 to Java Literals
UML2 to Java Literals [message #859116] Fri, 27 April 2012 09:16 Go to next message
Rogério Costa is currently offline Rogério Costa
I am developing a model-based tool, PIM -> PSM -> Code, and I am using EMF ATL to accomplish the M2M transformations. My problem is simple: My ATL mapping works betwen UML2 and Java metamodels, except in Primitive Types (Literal types).
If some with more experience could look to my files and take a shot, it will help me a lot!
UML metamodel: By URI, but you could use that as reference: UML.ecore;
Java metamodel: Java-20040316.ecore; (To be built gradually);
ATL mapping: UML2JAVA.atl;
My (UML) input Model: exampleUMLModel_PIM.xmi;
My (Java) output Model: out.j2se5; ==> At line 18 it is supposed to have a Primitive Type, right?
tanks in advance
Re: UML2 to Java Literals [message #873162 is a reply to message #859116] Thu, 17 May 2012 12:05 Go to previous messageGo to next message
This is my Atl configuration, hope this help a little more ... Should I need to register something more?
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
public class UML2_2_JAVA extends AbstractPIMPSM_Factory
    private IInjector injector;
    private IExtractor extractor;
    private IReferenceModel sourceMetamodel;
    private IReferenceModel targetMetamodel;
    private String transformationFilepath = null;
    private String sourceMetaModelFilepath = null;
    private String targetMetaModelFilepath = null;
    private String sourceDataFilepath = null;
    private String targetDataFilepath = null;
    private IModel targetModel;
    private IModel sourceModel;
    private ModelFactory factory;
    private ILauncher launcher;
    public UML2_2_JAVA()
        super();
    public IModel getTargetModel()
        return this.targetModel;
    /// From now on, there are the functions
    public void doCore() throws ATLCoreException
        CoreService.registerLauncher("EMF-specific VM", EMFVMLauncher.class);
        CoreService.registerFactory("EMF", EMFModelFactory.class);
        CoreService.registerExtractor("EMF", EMFExtractor.class);
        CoreService.registerInjector("EMF", EMFInjector.class);
        injector = CoreService.getInjector("EMF");
        extractor = CoreService.getExtractor("EMF");
        // Defaults
        this.factory = CoreService.getModelFactory("EMF");
        /*Resource specification*/
        Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
        Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("xmi",  UMLResource.Factory.INSTANCE);
        Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
        /*Type specification*/
        EPackage.Registry.INSTANCE.put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
        EPackage.Registry.INSTANCE.put("ecore", EcorePackage.eINSTANCE);
        EPackage.Registry.INSTANCE.put("h**p://www.omg.org/spec/UML/20110701", UMLPackage.eINSTANCE);
        EPackage.Registry.INSTANCE.put("h**p://www.omg.org/spec/XMI/20110701", UMLPackage.eINSTANCE);
        Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("j2se5", new EcoreResourceFactoryImpl());
    public void doMetaModels(String sourceTargetMMPath) throws ATLCoreException
    { this.doMetaModels(sourceTargetMMPath, null); }
    public void doMetaModels(String sourceMMPath, String targetMMPath) throws ATLCoreException
        // Metamodels
        this.sourceMetaModelFilepath = sourceMMPath;
        sourceMetamodel = factory.newReferenceModel();
        injector.inject(sourceMetamodel, UMLPackage.eNS_URI);
        if(targetMMPath != null) //This means, the metamodel is the same for both models (InputModel & OutputModel)
            this.targetMetaModelFilepath =  targetMMPath;
            targetMetamodel = factory.newReferenceModel();
            injector.inject(targetMetamodel, URI.createFileURI(targetMetaModelFilepath).toString());
    public void doModels(String sourceDM) throws ATLCoreException
         /// Creating models
        sourceModel = factory.newModel(sourceMetamodel);
        if(this.targetMetamodel == null)
        { targetModel = factory.newModel(this.sourceMetamodel);}
        else
        { targetModel = factory.newModel(this.targetMetamodel); }
        // Loading existing model
        this.sourceDataFilepath = sourceDM;
        injector.inject(sourceModel, URI.createFileURI(sourceDM).toString());
    public void doTrans(String transformationPath) throws ATLCoreException, MalformedURLException, IOException
        // Getting launcher
        launcher = (EMFVMLauncher)CoreService.getLauncher("EMF-specific VM");
        launcher.initialize(Collections.<String, Object> emptyMap());
        // Launching //TODO: REVER ISTO
        launcher.addInModel(sourceModel,"IN", "UML");
        launcher.addOutModel(targetModel, "OUT", "JAVA");
        // the loadModule function requires an absolute path to the ASM file
        this.transformationFilepath = transformationPath;
        URL asmFile = new File(transformationPath).toURI().toURL();
        Object loadedModule = launcher.loadModule(asmFile.openStream());
        //launcher.addLibrary("libName", new File("path").toURI().toURL().openStream());
        Map <String, Object> optionsTransf = new  TreeMap <String, Object>();
        optionsTransf.put("showSummary", "true");
        optionsTransf.put("printExecutionTime", "true");
        optionsTransf.put("continueAfterError", "true");
        optionsTransf.put("allowInterModelReferences", "true");
        //optionsTransf.put("step", "true");
        launcher.launch(ILauncher.DEBUG_MODE, new NullProgressMonitor(), optionsTransf, loadedModule);
    * Saving model
    public void doSave(String dataTargetfp) throws ATLCoreException
        this.targetMetaModelFilepath = dataTargetfp;
        //extractor.extract(targetModel, System.out, null);
        extractor.extract(targetModel, URI.createFileURI(dataTargetfp).toString());
Re: UML2 to Java Literals [message #873228 is a reply to message #873162] Thu, 17 May 2012 14:50 Go to previous messageGo to next message
Your original message seems to have fallen foul of the forum/newsgroup
synchronisation bug and not been sent to the newsgroups that are usually
the more reliable and consequently are the outlet monitored by committers.
An ATL query is more likely to get a response on the ATL than UML
newsgroups.
Ed Willink
> super();
> injector = CoreService.getInjector("EMF"); extractor =
> // Defaults
> @Override
> ATLCoreException
> @Override
> { // Metamodels
> targetMetamodel =
> @Override
> /// Creating models
> else
> URI.createFileURI(sourceDM).toString()); }
> // Getting launcher
> VM"); launcher.initialize(Collections.<String, Object>
> emptyMap());
> the ASM file
> <String, Object>();
> optionsTransf, loadedModule); }
> * Saving model
Re: UML2 to Java Literals [message #876601 is a reply to message #873228] Thu, 24 May 2012 19:26 Go to previous message
Thank you
Previous Topic:Make UML profile plug-in visible
Next Topic:UML Component creation
Current Time: Thu May 23 15:06:31 EDT 2013
Powered by FUDForum. Page generated in 0.01908 seconds
