Home » Eclipse Projects » Web Tools Project (WTP) » JSDT question - how can I recognize an optional function parameter ?
JSDT question - how can I recognize an optional function parameter ? [message #876316] Thu, 24 May 2012 07:07 Go to next message
Hoze Nadav is currently offline Hoze Nadav
I'm developing a plugin in eclipse with an editor that integrates with JS and I'm using the JSDT Core API to do so.
I need to add a new feature which depends on whether the last param of a function is optional.
The JSDoc is updated correctly - example:
* @param {String} userName The user name to use when logging in.
* @param {String} [accessLevel] The user accessLevel is optional.
function logIn(userName, accessLevel) {
but how do I access this information from jsdt ?
Appreciate your help.
Nadav
Re: JSDT question - how can I recognize an optional function parameter ? [message #876498 is a reply to message #876316] Thu, 24 May 2012 14:19 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
JSDT doesn't currently take notice of or record that information for its own future use, but the doc as a whole should be attached to the method declaration.
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:Open file outside project-Eclipse File System (EFS)
Next Topic:Reconverting an existing web project to a Dynamic
Current Time: Sat May 25 15:41:32 EDT 2013
Powered by FUDForum. Page generated in 0.01488 seconds
