Home » Eclipse Projects » Memory Analyzer » Parse large Heapdump (OOM: Java heap space )
Parse large Heapdump [message #873730] Fri, 18 May 2012 20:13 Go to next message
Sergi Ibar is currently offline Sergi Ibar
I trying to parse a dmp heapdump (IBM core dump). It size is 1Gb. But MAT raises a OOM "Java heap space".
I've tunning JVM with different memory configurations but it always crash.
The machine where i test it is a linux 64b with 6Gb, and MAT configuration that i use for run:
-vmargs -Xmx3g -XX:-UseGCOverheadLimit -XX:PermSize=1g
Anyone know how i can parse it or maybe i can't do it?
Thanks in advanced
Sergi
Re: Parse large Heapdump [message #874812 is a reply to message #873730] Mon, 21 May 2012 11:35 Go to previous messageGo to next message
Andrew Johnson is currently offline Andrew Johnson
Member
Is this a PHD or a system core dump?
I have reduced the memory requirements of MAT - see defect 374960: OutOfMemoryError parsing large DTFJ PHD file.
Try a latest development build to see if that helps.
Re: Parse large Heapdump [message #875437 is a reply to message #874812] Tue, 22 May 2012 14:51 Go to previous messageGo to next message
Hi Andrew,
It's a system core dump (DMP).
I'm using MemoryAnalyzer-1.1.1.20110824-linux.gtk.x86_64 to parser, i think it's the last build, right?
Re: Parse large Heapdump [message #876394 is a reply to message #875437] Thu, 24 May 2012 10:03 Go to previous message
Member
Try a nightly build from here: http://www.eclipse.org/mat/snapshotBuilds.php.
Previous Topic:Steps to write a plugin of ParseSnapshotApp and deploy to MAT MCP
Next Topic:My plugin is not loaded
Current Time: Wed May 22 12:39:40 EDT 2013
Powered by FUDForum. Page generated in 0.02835 seconds
