Home » Modeling » UML2 » Make UML profile plug-in visible
Make UML profile plug-in visible [message #876290] Thu, 24 May 2012 06:14 Go to next message
Tex Iano is currently offline Tex Iano
Member
I have created an eclipse plug-in with my a UML profile I created.
First a question:
My profile has the name "MyProfile". Similar as "Ecore" or "UML2". However, my packages are now named:
com.myfirstprofile.MyProfile
For Ecore the packages are named:
org.eclipse.ecore etc
How have you managed to name your package with lower case letters and the model with upper case letters? I can only decide between these two alternatives.
Well, ok, now I have my plugin. The package is expected to be located using a pathmap:
pathmap://UML_PROFILES/MyProfile.profile.uml
I have added the mapping to the plugin.xml. Works too.
So, now my question is: How can I find my profile in eclipse to apply it? Smile Of course I can load the profile.uml file as resource. But then the file is added as profile. But I want that in the final model "pathmap://UML_PROFILES ..." is used to locate my profile.
So when getting the list of available profiles, how can I make my profile available using the pathmap location?
Tex
Re: Make UML profile plug-in visible [message #876322 is a reply to message #876290] Thu, 24 May 2012 07:22 Go to previous message
It's always a good idea to study Eclipse code that works.
The magic EAnnotations in the UML models should show how to name
packages an files as you like.
The uml.resources plugin.xml shows how to configure pathmap.
Ed Willink
On 24/05/2012 11:14, Tex Iano wrote:
> First a question:
> alternatives.
> using a pathmap:
> it? :) Of course I can load the profile.uml file as resource. But then
> Tex
Previous Topic:Check profile application
Next Topic:UML2 to Java Literals
Current Time: Mon May 20 04:45:10 EDT 2013
Powered by FUDForum. Page generated in 0.01570 seconds
