Home » Eclipse Projects » BIRT » Export feature in report(Export feature in report - in SOA Soft environment)
Export feature in report [message #874963] Mon, 21 May 2012 17:37 Go to next message
A R is currently offline A R
I am using BIRT with SOA Soft. Where my reports will be deployed in SOA Soft Repository Manger (SOA RM). When I am running report in BIRT designer I am able to find export feature. But when I am deploy the report in web portal in SOA RM, I am not able to export the report.
I am looking for the feature by which I can export my report, after deploying in to SOA RM web portal.
Please let me know further if any information required.
Thanks in advance
AR
Re: Export feature in report [message #875380 is a reply to message #874963] Tue, 22 May 2012 12:17 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
It does not look like SOA is integrating the viewer, just the engine.
Can you post a screenshot of a report in the app?
Jason
On 5/21/2012 5:37 PM, Amarnath A wrote:
> Thanks in advance
> AR
Jason Weathersby
BIRT Exchange
Re: Export feature in report [message #875489 is a reply to message #875380] Tue, 22 May 2012 16:52 Go to previous messageGo to next message
Hi Jason ,
Please find the attachment.
AR
Re: Export feature in report [message #875499 is a reply to message #875489] Tue, 22 May 2012 17:17 Go to previous messageGo to next message
What happens if you change the url by replacing the word run with frameset?
Or try leaving it with run and add &__format=pdf to the url. If the
format parameter is already in the url change its value to pdf.
Jason
On 5/22/2012 4:52 PM, A R wrote:
> Hi Jason ,
> Thanks
> AR
Jason Weathersby
BIRT Exchange
Re: Export feature in report [message #875523 is a reply to message #875499] Tue, 22 May 2012 18:37 Go to previous messageGo to next message
Hi Jason,
I am not clear with the prev response, can u help me in more detail. Please find the url I am using to deploye the report.
<DB_URL/rm/birt/run?__report=reports/demo_report - Copy.rptdesign&libraryID=422:29&database_schema_name=&server_url=DB_URL
AR
[Updated on: Tue, 22 May 2012 18:38]
Report message to a moderator
Re: Export feature in report [message #876069 is a reply to message #875523] Wed, 23 May 2012 17:05 Go to previous messageGo to next message
I am not sure how they have integrated birt but did you try
<DB_URL/rm/birt/frameset?__report=reports/demo_report -
or
Copy.rptdesign&libraryID=422:29&database_schema_name=&__format=pdf&server_url=DB_URL
Jason
On 5/22/2012 6:37 PM, A R wrote:
> Hi Jason,
> Can u help me in more detail. Please find the url I am using to deploye
> the report.
> Thanks
> AR
Jason Weathersby
BIRT Exchange
Re: Export feature in report [message #876076 is a reply to message #876069] Wed, 23 May 2012 17:26 Go to previous messageGo to next message
Hello Jason,
I tried the suggested feature. Its not working.
AR
Re: Export feature in report [message #876089 is a reply to message #876076] Wed, 23 May 2012 18:01 Go to previous message
Does SOA have a support forum? You may need to talk with them.
Jason
On 5/23/2012 5:26 PM, A R wrote:
> Hello Jason,
> Thanks
> AR
Jason Weathersby
BIRT Exchange
Previous Topic:How to retrieve specific Row Elements
Next Topic:Use computed column to concatenate data set data
Current Time: Fri May 24 14:51:11 EDT 2013
Powered by FUDForum. Page generated in 0.01716 seconds
