| Are Dojo themes available in EDT [message #871117] |
Thu, 10 May 2012 19:32  |
Chris Fourie Messages: 4 Registered: May 2012 |
Junior Member |
I am new to EDT and just learning through doing the sample applications. I have referred to some IBM EGL documentation for clues as to how some things may work with some success. Is it possible to set the Dojo theme from within EDT? if so, how can I do it? Where can I find EDT specific documentation, if it more complete?
Chris.
| Re: Are Dojo themes available in EDT [message #875563 is a reply to message #875551] |
Tue, 22 May 2012 20:55  |
Junior Member |
Hi Theresa,
Thank you again. Item 1 is a bit complicated, but seems to me to be a requirement for most modern UI aspects that use a tree. It would be great to see the node level icon management included in future releases.
Similarly, Item 3 (Toolbar) is a great way to condense functionality into on-line business applications where screen real estate is at a premium and I, for one, would use it.
I'll play around with Item 2 as it seems to address my issue of adapting to some degree to the user's screen resolution.
So far, this looks to be shaping up to be a great product and I look forward to the next release.
Kind Regards,
Chris.
FUDForum. Page generated in 0.02386 seconds
