| SWT AWT Bridge Issues [message #8715] |
Tue, 28 October 2008 04:12  |
Rahul Kamdar Messages: 63 Registered: July 2009 |
Member |
I am making use of SWT_AWT bridge in order to bring panels from my Swing/AWT
application into Eclipse SWT environment. I cannot make use of Albireo since
I have a restriction to stick to Eclipse 3.2 and can't go for Eclipse 3.3 or
higher.
I have broken down my Swing application's window into panels and then
embedded each of these into a JApplet which is added to the frame returned
by SWT_AWT. Some of the problems I am encountering are as follows:
1] Label/buttons within the panel often is not visible until the user moves
his mouse over the area where this label/buttons are located
2] On fast switching between the Eclipse views, often the panel/applet area
embedded inside the Eclipse view appears/becomes blank (anything related to
explicit setFocus?)
For these issues are there any possible resolutions or are these known
issues with the SWT_AWT Bridge framework?
I would be really grateful for any help/direction.
Rahul
| Re: SWT AWT Bridge Issues [message #8754 is a reply to message #8730] |
Wed, 29 October 2008 05:45  |
Member |
Hi Johannes,
Thanks for the reply about your case! Sounds good to me... I'll start
plugging around and try to use it. Any idea if there is any place where I
can find information on what might NOT work in case of 3.2?
Rahul
"Johannes Utzig" <mail@jutzig.de> wrote in message
news:ge75om$609$1@build.eclipse.org...
> Rahul Kamdar schrieb:
>> Swing/AWT
>> since
>> or
>> higher.
>> returned
>> moves
>> area
>> to
>> explicit setFocus?)
>> Thanks,
>> Rahul
> Hi Rahul,
> it might not be officially supported, but I'm running Albireo successfully
> on Eclipse 3.2 with SWT 3.2 so you might as well give it a shot.
> Best regards,
> Johannes
| Re: SWT AWT Bridge Issues [message #574608 is a reply to message #8715] |
Tue, 28 October 2008 09:56  |
Johannes Utzig Messages: 329 Registered: July 2009 |
> higher.
> explicit setFocus?)
> Rahul
Hi Rahul,
successfully on Eclipse 3.2 with SWT 3.2 so you might as well give it a
shot.
Johannes
| Re: SWT AWT Bridge Issues [message #574647 is a reply to message #8730] |
Member |
Hi Johannes,
Rahul
>> Swing/AWT
>> since
>> or
>> higher.
>> returned
>> moves
>> area
>> to
>> explicit setFocus?)
>> Thanks,
>> Rahul
> Hi Rahul,
> Best regards,
> Johannes
FUDForum. Page generated in 0.01715 seconds
