Home » Eclipse Projects » Rich Client Platform (RCP) » java.lang.RuntimeException: Application "id" could not be found(Unable to launch the GUI of an Eclipse RCP application developed on Eclipse 3.7.2)
icon9.gif  java.lang.RuntimeException: Application "id" could not be found [message #875148] Tue, 22 May 2012 04:22 Go to next message
dhananjay madiraju is currently offline dhananjay madiraju
We recently upgrade out Eclipse RCP application from version 3.5.2 to 3.7.2.
We were able to launch the application from within the Eclipse 3.7.2 environment, but when the pde-ant build is done, and the application is run from outside the 3.7.2 environment the GUI isn't coming up and the below error is seen in < path to configuration folder>\
!SESSION 2012-05-21 23:56:57.141 -----------------------------------------------
eclipse.buildId=unknown
java.fullversion=JRE 1.6.0 IBM J9 2.4 Windows Server 2008 R2 x86-32 jvmwi3260sr9-20110203_74623 (JIT disabled, AOT disabled)
J9VM - 20110203_074623
GC - 20101027_AA
Framework arguments: gui
Command-line arguments: -os win32 -ws win32 -arch x86 gui -debug
!ENTRY org.eclipse.osgi 2 0 2012-05-21 23:56:59.204
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-05-21 23:56:59.204
!MESSAGE Bundle update@plugins/org.apache.lucene.analysis_2.9.1.v201101211721.jar was not resolved.
!SUBENTRY 2 org.apache.lucene.analysis 2 0 2012-05-21 23:56:59.204
!MESSAGE Missing required bundle org.apache.lucene.core_[2.9.1,3.0.0).
!MESSAGE Bundle update@plugins/org.apache.lucene_2.9.1.v201101211721.jar was not resolved.
!SUBENTRY 2 org.apache.lucene 2 0 2012-05-21 23:56:59.204
!ENTRY org.eclipse.osgi 2 0 2012-05-21 23:56:59.235
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2012-05-21 23:56:59.235
!MESSAGE Bundle com.ibm.ecm.configmgr.app.ce_5.1.1.201205212153 [7] was not resolved.
!SUBENTRY 2 com.ibm.ecm.configmgr.app.ce 2 0 2012-05-21 23:56:59.235
!MESSAGE Missing required bundle org.eclipse.help.ui_3.3.101.
!MESSAGE Missing required bundle org.eclipse.help.webapp_3.3.101.
!MESSAGE Missing required bundle com.ibm.ecm.configmgr.ui_0.0.0.
!MESSAGE Bundle com.ibm.ecm.configmgr.ui_5.1.1.201205212153 [9] was not resolved.
!SUBENTRY 2 com.ibm.ecm.configmgr.ui 2 0 2012-05-21 23:56:59.235
!MESSAGE Bundle org.apache.lucene.analysis_2.9.1.v201101211721 [21] was not resolved.
!SUBENTRY 2 org.apache.lucene.analysis 2 0 2012-05-21 23:56:59.235
!MESSAGE Bundle org.apache.lucene_2.9.1.v201101211721 [22] was not resolved.
!SUBENTRY 2 org.apache.lucene 2 0 2012-05-21 23:56:59.235
!MESSAGE Missing optionally required bundle org.apache.lucene.analysis_[2.9.1,3.0.0).
!MESSAGE Missing optionally required bundle org.apache.lucene.highlighter_[2.9.1,3.0.0).
!MESSAGE Missing optionally required bundle org.apache.lucene.memory_[2.9.1,3.0.0).
!MESSAGE Missing optionally required bundle org.apache.lucene.queries_[2.9.1,3.0.0).
!MESSAGE Missing optionally required bundle org.apache.lucene.snowball_[2.9.1,3.0.0).
!MESSAGE Missing optionally required bundle org.apache.lucene.spellchecker_[2.9.1,3.0.0).
!MESSAGE Missing optionally required bundle org.apache.lucene.misc_[2.9.1,3.0.0).
!MESSAGE Bundle org.eclipse.help.base_3.6.2.v201202080800 [48] was not resolved.
!SUBENTRY 2 org.eclipse.help.base 2 0 2012-05-21 23:56:59.235
!MESSAGE Missing required bundle org.apache.lucene_[2.9.0,3.0.0).
!MESSAGE Missing required bundle org.apache.lucene.analysis_[2.9.0,3.0.0).
!MESSAGE Missing optionally required bundle org.eclipse.ant.core_3.2.200.
!MESSAGE Bundle org.eclipse.help.ui_3.5.101.r37_20110819 [49] was not resolved.
!SUBENTRY 2 org.eclipse.help.ui 2 0 2012-05-21 23:56:59.235
!MESSAGE Missing required bundle org.eclipse.help.base_[3.5.0,4.0.0).
!MESSAGE Bundle org.eclipse.help.webapp_3.6.1.r37_20110929 [50] was not resolved.
!SUBENTRY 2 org.eclipse.help.webapp 2 0 2012-05-21 23:56:59.235
!MESSAGE Bundle org.eclipse.swt.gtk.aix.ppc_3.7.2.v3740f [57] was not resolved.
!MESSAGE Bundle org.eclipse.swt.gtk.hpux.ia64_32_3.7.2.v3740f [58] was not resolved.
!MESSAGE Bundle org.eclipse.swt.gtk.linux.s390x_3.7.2.v3740f [59] was not resolved.
!MESSAGE Bundle org.eclipse.swt.gtk.linux.s390_3.7.2.v3740f [60] was not resolved.
!MESSAGE Bundle org.eclipse.swt.gtk.linux.x86_3.7.2.v3740f [61] was not resolved.
!MESSAGE Bundle org.eclipse.swt.gtk.solaris.sparc_3.7.2.v3740f [62] was not resolved.
!ENTRY org.eclipse.osgi 4 0 2012-05-21 23:56:59.251
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "com.ibm.ecm.configmgr.app.ce.application" could not be found in the registry. The
applications available are: org.eclipse.equinox.app.error.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
at java.lang.reflect.Method.invoke(Method.java:611)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
The application name configmgr.exe and the .ini file name do match (configmr.ini)
Content of .ini file is
-vm
C:/Program Files (x86)/IBM/FileNet/ContentEngine/_cejvm/jre/bin
gui
-debug
-vmargs
-Djava.compiler=none
-Djava.util.logging.config.file=C:/Program Files (x86)/IBM/FileNet/ContentEngine/tools/configure/configuration/cmlogging.properties
Please suggest whats wrong with the pde-build / application / any known issues with 3.7.2 related to the above errors.
Re: java.lang.RuntimeException: Application &quot;id&quot; could not be found [message #875201 is a reply to message #875148] Tue, 22 May 2012 06:06 Go to previous messageGo to next message
Libor Jelinek is currently offline Libor Jelinek
Does your PDE Build log contain any errors?
Are all mentioned plug-ins present in plugins/ folder of final
application archive? E.g. is there
org.apache.lucene.analysis_2.9.1.v201101211721.jar and
org.apache.lucene_2.9.1.v201101211721.jar, ...?
Are you able to run your RCP app at least from IDE?
Cheers
Libor
> 3.7.2. We were able to launch the application from within the Eclipse
> GC - 20101027_AA
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !MESSAGE Bundle
> not resolved.
> was not resolved.
> not resolved.
> resolved.
> not resolved.
> resolved.
> resolved.
> resolved.
> resolved.
> resolved.
> not resolved.
> not resolved.
> resolved.
> resolved.
> not resolved.
> !STACK 1
> registry. The
> at
> at
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> (configmr.ini)
> -vm
> gui
> -debug
> -vmargs
Re: java.lang.RuntimeException: Application &quot;id&quot; could not be found [message #875221 is a reply to message #875201] Tue, 22 May 2012 06:47 Go to previous messageGo to next message
No the PDE build was successful. I had some linux/aix motif related issues, which I fixed by replacing motif with gtk (Eclipse replaced support of motif with gtk)
Yes all the files mentioned in the error log do exist in the plugins folder. And I am able to run the application from within the Eclipse IDE.
Re: java.lang.RuntimeException: Application &quot;id&quot; could not be found [message #987181 is a reply to message #875221] Sat, 24 November 2012 03:24 Go to previous messageGo to next message
Sandeep Yohans is currently offline Sandeep Yohans
I am also facing the same problem.
My Eclipse RCP Application is running fine from the IDE but when I'm running it using the ".exe" generated after exporting it, It gives this message in log file:
!SESSION 2012-11-24 13:22:38.484 -----------------------------------------------
java.version=1.6.0_30
Command-line arguments:  -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.osgi 4 0 2012-11-24 13:22:39.406
!STACK 1
java.lang.RuntimeException: Application "" could not be found in the registry. The applications available are: org.eclipse.equinox.app.error.
I'm exporting it using the "Eclipse Product export wizard" in the "Exporting" section under the "Overview" tab of ".(dot)product" file.
Is this some kind of bug?
I am still not able to find any particular solution on this.
Thanks in advance.
[Updated on: Mon, 26 November 2012 04:18]
Report message to a moderator
Re: java.lang.RuntimeException: Application &quot;id&quot; could not be found [message #987187 is a reply to message #987181] Sat, 24 November 2012 05:22 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de Alwis
Sandeep, your issue is likely that your app bundle doesn't include its plugin.xml -- check the "Build" tab in the manifest editor.
Dhananjay, if you've verified that you're including the lucene bundles, the start your app with the OSGi console and use the "diag" command to understand why those bundles are failing to load. The following link is helpful:
http://wiki.eclipse.org/Where_Is_My_Bundle
Re: java.lang.RuntimeException: Application &quot;id&quot; could not be found [message #987352 is a reply to message #987187] Mon, 26 November 2012 04:21 Go to previous message
Thank you Brian, it did work.
Previous Topic:Renaming an item in a TreeView
Next Topic:Unable to check for file extension in expression?
Current Time: Thu May 23 23:36:30 EDT 2013
Powered by FUDForum. Page generated in 0.02002 seconds
