Home » Eclipse Projects » Eclipse 4 » Is it possible to listen for a workbench to be closed by force?
Is it possible to listen for a workbench to be closed by force? [message #874938] Mon, 21 May 2012 16:36 Go to next message
Josh Davis is currently offline Josh Davis
Previously in our 3.x code we would do this.
new IWorkbenchListener{
        public boolean preShutdown(final IWorkbench workbench, final boolean forced) {
            if (forced) {
                return true;
            //Logic here to determine if we really want the workbench to close.
I couldn't find a e4 workbench listener but I did find a IWindowCloseListener
new IWindowCloseHandler {
   public boolean close(final MWindow window) {
       //Logic here to determine if we want the window to close.
The only problem with the IWindowCloseListener is that I can't find a way to determine if the window is being forced closed. I would assume that if the workbench is being forced closed that the window would also be forced closed.
Is there a way to determine if the MWindow is being forced closed?
I checked the org.eclipse.e4.ui.workbench.IWorkbench API and it only has a run() and close() method. I didn't see any way to attach some sort listener to it that is comparable to the 3.x IWorkbenchListener, so that is why I converted from the Workbench to the MWindow.
Re: Is it possible to listen for a workbench to be closed by force? [message #880138 is a reply to message #874938] Fri, 01 June 2012 10:04 Go to previous message
Paul Webster is currently offline Paul Webster
That's not available yet. There's still some work to do on the Eclipse4 lifecycle side.
PW
Previous Topic:Binding Contexts and Binding Tables
Next Topic:Project context menu
Current Time: Tue Jun 18 02:13:19 EDT 2013
Powered by FUDForum. Page generated in 0.01519 seconds
