| Re: Setting Persistent Global Variable from DataSet [message #874886] |
Mon, 21 May 2012 13:45 |
Jason Weathersby Messages: 9167 Registered: July 2009 |
Reference the value using dataSetRow syntax. Take a look at the
attached example.
Jason
On 5/19/2012 4:35 AM, TO C wrote:
> I'm trying to set a Persistent Global Variable from the column of a
> dataset.
> I've tried using OnFetch as below:
> var myvar = this.getDataRowData().getColumnValue("Variable");
> reportContext.setPersistentGlbalVariable("VariableData", myvar.toString());
> This isn't working though.
> I want a Persistent Global Variable set to the Value of the column
> Variable (it'll be the same across the dataset).
> Any ideas?
Jason Weathersby
BIRT Exchange
FUDForum. Page generated in 0.01580 seconds
