Home » Modeling » ATL » EReference
EReference [message #874821] Mon, 21 May 2012 11:48 Go to next message
Kosala Yapa is currently offline Kosala Yapa
Hi there,
class Module{ name, address}
class ModuleList{EReference moduleItem of the type Module}
class Model{name, address}
class ModelList{EReference modelItem of the type Model}
problem:
-- @path source=file:/C:/.../Module.ecore
-- @path target=file:/C:/.../Model.ecore
create OUT : target from IN : source;
rule Rule_1{
from
a:source!ModuleList
to
d:target!ModelList(
modelItem.name <- a.moduleItem.name
Error: no viable alternative at input '.'
Can someone tell me how to resolve this issue? In some other terms, how to use EReferences in ATL programming? Could someone show me a simple example?
Thanks in advance
K
Re: EReference [message #955202 is a reply to message #874821] Tue, 23 October 2012 11:54 Go to previous message
Cesar Caves is currently offline Cesar Caves
I think you need a matched rule like the following
rule Module_2_Model {
  from
    input : source!Module
  to
    output : target!Model (
      name <- input.name,
      address <- input.address
So in the bindings of your rule you could write: modelItem <- a.moduleItem
[Updated on: Tue, 23 October 2012 12:02]
Report message to a moderator
Previous Topic:write sequence
Next Topic:How to inject code into java model MethodDeclaration
Current Time: Sat May 25 00:14:56 EDT 2013
Powered by FUDForum. Page generated in 0.01488 seconds
