| No Java Application with Window Builder [message #874803] |
Mon, 21 May 2012 11:23  |
User Java Messages: 1 Registered: May 2012 |
Junior Member |
I use some libraries like Swing or SWT but for embedded systems (I have not the source code).
I would like to create a designer page with palette, etc...
I created a toolkit with extension point for window builder but I have a problem to parse my code.
Librairies are not dependent of Swing or AWT and it is not executable like a Java application.
I would like to know if we can use WindowBuilder with a non Java application (cannot run as java application)? Like GWT I think (no?)
Or, how can I find how GWT work with WindowBuilder?
[Updated on: Mon, 21 May 2012 11:33] Report message to a moderator
| Re: No Java Application with Window Builder [message #874914 is a reply to message #874803] |
Mon, 21 May 2012 15:41  |
Eric Clayberg Messages: 737 Registered: July 2009 Location: Boston, MA |
GWT Designer is also open source and based on WindowBuilder, so you can look at the code for GWT Designer directly.
WindowBuilder could be used with any language, but you would need to provide a parser for that language. Currently, WB supports Java and XML based UIs. You could extend it to support some other language (like C/C+) if you wanted to.
FUDForum. Page generated in 0.01680 seconds
