Home » Modeling » EMF Store » Problems when running the EMF Store client
Problems when running the EMF Store client [message #874787] Mon, 21 May 2012 10:39
Lily Li is currently offline Lily Li
Hi, I'm starting with emfstore and followed the tutorials in the website.
I use Eclipse helios and have installed
1. EMFStore Client (Incubation)
2. EMFStore Client UI(Incubation)
3. EMFStore Common (Incubation)
4. EMFStore ECP Integration (Incubation)
5. EMFStore Server (Incubation)
in Version 0.8.9
The EMFStore Server starts Ok. I used the library example.
The problem is
After I run the EMFStore Client and create new project in the EMFStore Client, I can“t new model element. It means there is no "New model element", when I right click on the created project. There are share project, import model element, export model element and so on.
So how to solve this problem? How can I find the library model elements in the EMFStore Client?
Thanks a lot if you could give me the answer.
Previous Topic:IMPORTANT PLEASE READ: This newsgroup moved to the EMFT newsgroup
Next Topic:Connection between EMFStore server and client
Current Time: Tue May 21 15:57:25 EDT 2013
Powered by FUDForum. Page generated in 0.05687 seconds
