Home » Eclipse Projects » Buckminster » Ca y CQuery refer to another CQuery rather than an RMap?
Ca y CQuery refer to another CQuery rather than an RMap? [message #874565] Mon, 21 May 2012 02:54 Go to next message
Eike Stepper is currently offline Eike Stepper
I wonder if I can "wrap" a CQuery in another CQuery like this:
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="local.cquery">
<cq:advisorNode namePattern="org\.eclipse\..*\.source" skipComponent="true"/>
</cq:componentQuery>
Obviously not. The build produces this exception:
[java] java.lang.NullPointerException
[java] at org.eclipse.buckminster.core.query.model.ComponentQuery.getExpandedRootRequest(ComponentQuery.java:193)
[java] at org.eclipse.buckminster.core.resolver.MainResolver.resolve(MainResolver.java:66)
[java] at org.eclipse.buckminster.core.commands.Import.internalRun(Import.java:175)
[java] at org.eclipse.buckminster.core.commands.WorkspaceInitCommand.internalRun(WorkspaceInitCommand.java:156)
[java] at org.eclipse.buckminster.core.commands.WorkspaceCommand.run(WorkspaceCommand.java:91)
[java] at org.eclipse.buckminster.cmdline.AbstractCommand.basicRun(AbstractCommand.java:200)
[java] at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:350)
[java] at org.eclipse.buckminster.cmdline.Headless.run(Headless.java:145)
[java] at org.eclipse.buckminster.cmdline.Headless.start(Headless.java:165)
[java] at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
[java] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
[java] at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
[java] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
[java] at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
[java] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
[java] at java.lang.reflect.Method.invoke(Method.java:597)
[java] at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
[java] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
[java] at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
[java] at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
I guess this is not something that's supposed to work somehow?
Is there another way to suppress the materialization of source plugins conditionally (e.g. in a remote build as opposed to a local workspace setup)?
Cheers
/Eike
http://www.esc-net.de
Re: Ca y CQuery refer to another CQuery rather than an RMap? [message #874623 is a reply to message #874565] Mon, 21 May 2012 05:16 Go to previous message
Thomas Hallgren is currently offline Thomas Hallgren
On 05/21/2012 08:54 AM, Eike Stepper wrote:
No. You can nest rmaps (by using redirects) but not cqueries.
The property buckminster.download.source controls automatic download of sources. It is set to true by default when you
run in the IDE and false when you run headless. It will however not affect explicitly declared dependencies to source
bundles. In order to override them in different ways, you'll need to use two different cquery files.
- thomas
Previous Topic:Unable to load runtime repository
Next Topic:Buckminster for Eclipse 3.7 (Indigo) is now available
Current Time: Wed May 22 21:16:55 EDT 2013
Powered by FUDForum. Page generated in 0.01800 seconds
