| Unable to load runtime repository [message #874169] |
Sun, 20 May 2012 00:53  |
Eike Stepper Messages: 5154 Registered: July 2009 |
A while back I started to use a bundle pool for my various IDE installations. Now Buckminster logs the following message
to the console during the import of my MSpec:
Unable to load runtime repository: No repository found at file:/C:/develop/bin/eclipse-cdo/.
I guess that is because my IDE installation does not contain features/plugins folders anymore. It ssems that this
doesn't lead to severe problems but it strikes me that the usage of the bundle pool could make the resolution/download
phases much faster. Would that be right? Is there something I can do?
Cheers
/Eike
http://www.esc-net.de
| Re: Unable to load runtime repository [message #874519 is a reply to message #874262] |
Mon, 21 May 2012 00:32  |
Am 20.05.2012 12:21, schrieb Thomas Hallgren:
> That's definitely a bug. The runtime repo should be found regardless of location and since using it is meant to be an
> optimization only
I've filed https://bugs.eclipse.org/bugs/show_bug.cgi?id=380097
> (it's used for materialization, not for resolution),
Sorry, that's indeed true.
> an error should't cause problems.
I can no longer reproduce that the operation stops at that point. The console message is reproducible, though.
Cheers
/Eike
> - thomas
> On 05/20/2012 07:13 AM, Eike Stepper wrote:
>> Correction:
>> It seems that the console message is in fact an indication for a fatal problem. The import operation does not continue
>> after the message.
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
>> Am 20.05.2012 06:53, schrieb Eike Stepper:
>>> Hi,
>>> message to the console during the import of my MSpec:
>>> Cheers
>>> /Eike
FUDForum. Page generated in 0.01830 seconds
