Home » Eclipse Projects » SWTBot » SWTBot with Maven 2.2.1(SWTBot with Maven 2.2.1)
SWTBot with Maven 2.2.1 [message #870516] Tue, 08 May 2012 09:56 Go to next message
prakash jv is currently offline prakash jv
We have been looking for unit test framework for unit testing SWT components in our RCP application developed in eclipse galileo 3.5.
We found SWTBot supports the better UI testing and wanted to additional details reagrding its support for maven 2.2.1.
Does SWTBot work with projects which are mavenized with maven 2.2.1?
Our aim of adding the unit tests for UI components is for better build quality. So we would want these Unit tests to be run everytime we build our assembly. As of now we use Junit4 for running our JUnits and they run with maven outside eclipse.
Does SWTBot support running the UI unit tests outside eclipse using maven?
Re: SWTBot with Maven 2.2.1 [message #870647 is a reply to message #870516] Wed, 09 May 2012 04:08 Go to previous messageGo to next message
Lorenzo Bettini is currently offline Lorenzo Bettini
in
http://code.google.com/a/eclipselabs.org/p/emf-components/
we run swtbot tests with maven/tycho
hope this helps
cheers
Lorenzo
Lorenzo Bettini, PhD in Computer Science, DI, Univ. Torino
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: SWTBot with Maven 2.2.1 [message #872641 is a reply to message #870647] Wed, 16 May 2012 10:07 Go to previous messageGo to next message
Hey Lorenzo Bettini, thanks for your reply !!
It would be very helpful if you could provide more details on how maven can be used for running SWTBot tests? Also, I came across a information that SWTBot tests can be run only with maven3, any hints on this?
Prakash !!
Re: SWTBot with Maven 2.2.1 [message #874219 is a reply to message #872641] Sun, 20 May 2012 03:22 Go to previous message
> Prakash !!
HI
I only tried swtbot tests with tycho (see the code at
http://code.google.com/a/eclipselabs.org/p/emf-components/) so I cannot
help with running them with maven only (if that is what you need).
have you looked at this? http://wiki.eclipse.org/SWTBot/Maven
cheers
Lorenzo
Previous Topic:Error in MANIFEST.MF of SWTBot test plugin
Next Topic:Launch SWTBot test in an opened Eclipse window
Current Time: Fri May 24 15:45:29 EDT 2013
Powered by FUDForum. Page generated in 0.02197 seconds
