| Configuring a Packaged MacOSX app [message #873688] |
Fri, 18 May 2012 17:02  |
Amanda Mitchell Messages: 7 Registered: May 2012 |
Junior Member |
I am working on getting Jubula up and running on Mac 10.7 and I cannot get my RCP AUT configured properly in Jubula, so that it opens the app, while the folders that need to be accessed are in the packaged app. The app is packaged using the EclipseOSXRepackager.
I have tried setting the working directory and using key aspects from the .plist as arguments to launch the correct plugins, but that never seems to work, because my App cannot find the companion launcher jar. Even though it can be found in the directory I'm pointing at for the working directory. However, if i drop and drag the same executable into the command line, it will launch my app, without any issue.
I found a work around, where i create sym links to the folders that I need in the directory of the .app and set that directory as my working directory.
Does anyone know specifically how to configure a package AUT to launch properly via Jubula? I'd prefer not to have to use the work around if necessary.
FUDForum. Page generated in 0.02138 seconds
