If your package is one that corresponds to XML schema without a
targetNamespace (which appears to be the case, given there are no
namespace in your XML), it's important that you register the generated
XyzResourceFactoryImpl to handle reading of your data file.
On 18/05/2012 10:05 AM, Kosala Mising name wrote:
> Hi there,
> The input for the source model(ecore) is xml and output from the
> target model(ecore) is xmi. Transformation is written in ATL.
> Source: XML->ecore model
> Transformation: ATL
> Target: ecore ->xmi
> Step1) I have xml input file(data.xml):
> <?xml version="1.0"?>
> <DeviceItem Name="ppp1" IsSelected="false"
> <ModuleList> <ModuleItem Name="m1"
> IsSelected="false" ModuleReference="Rm1"> </ModuleItem>
> <ModuleItem Name="m2" IsSelected="false"
> ModuleReference="Rm2"> </ModuleItem> <ModuleItem
> Name="m3" IsSelected="false"
> ModuleReference="Rm3">
> </ModuleItem> <ModuleItem Name="m4"
> IsSelected="false" ModuleReference="Rm4"> </ModuleItem>
> </ModuleList>
> </DeviceItem>
> Step2) I created XML schema for this input file and then created ecore
> model using eclipse EMF project(source model).
> Step3)I created another ecore model(target model) and wrote the
> transformation in ATL.
> Error: Error loading data.xml:
> org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri
> 'null' not found.
> Can someone find/hint how to solve this issue?
> Thanks in advance
> Kosala
