Home » Modeling » M2T (model-to-text transformation) » XML input to ecore
XML input to ecore [message #873428] Fri, 18 May 2012 04:05 Go to next message
Kosala Yapa is currently offline Kosala Yapa
Hi there,
The input for the source model(ecore) is xml and output from the target model(ecore) is xmi. Transformation is written in ATL.
Source: XML->ecore model
Transformation: ATL
Target: ecore ->xmi
Step1) I have xml input file(data.xml):
<?xml version="1.0"?>
<DeviceItem
Name="ppp1"
IsSelected="false"
<ModuleList>
<ModuleItem
Name="m1"
IsSelected="false"
ModuleReference="Rm1">
</ModuleItem>
<ModuleItem
Name="m2"
IsSelected="false"
ModuleReference="Rm2">
</ModuleItem>
<ModuleItem
Name="m3"
IsSelected="false"
ModuleReference="Rm3">
</ModuleItem>
<ModuleItem
Name="m4"
IsSelected="false"
ModuleReference="Rm4">
</ModuleItem>
</ModuleList>
</DeviceItem>
Step2) I created XML schema for this input file and then created ecore model using eclipse EMF project(source model).
Step3)I created another ecore model(target model) and wrote the transformation in ATL.
Error: Error loading data.xml: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'null' not found.
Can someone find/hint how to solve this issue?
Thanks in advance
Kosala
Re: XML input to ecore [message #873433 is a reply to message #873428] Fri, 18 May 2012 04:15 Go to previous message
Ed Merks is currently offline Ed Merks
Kosala,
If your package is one that corresponds to XML schema without a
targetNamespace (which appears to be the case, given there are no
namespace in your XML), it's important that you register the generated
XyzResourceFactoryImpl to handle reading of your data file.
On 18/05/2012 10:05 AM, Kosala Mising name wrote:
> Hi there,
> Transformation: ATL
> Target: ecore ->xmi
> <DeviceItem Name="ppp1" IsSelected="false"
> <ModuleList> <ModuleItem Name="m1"
> IsSelected="false" ModuleReference="Rm1"> </ModuleItem>
> <ModuleItem Name="m2" IsSelected="false"
> ModuleReference="Rm2"> </ModuleItem> <ModuleItem
> Name="m3" IsSelected="false"
> </ModuleItem> <ModuleItem Name="m4"
> IsSelected="false" ModuleReference="Rm4"> </ModuleItem>
> </ModuleList>
> </DeviceItem>
> 'null' not found.
> Thanks in advance
> Kosala
Previous Topic:Example Hello World - Acceleo - M2T
Next Topic:[Acceleo]I don't want to chang the timestamp when the content is not changed
Current Time: Thu May 23 05:17:11 EDT 2013
Powered by FUDForum. Page generated in 0.04309 seconds
