| Exception opening models with Papyrus editor [message #817844] |
Sat, 10 March 2012 14:03  |
Luís de Sousa Messages: 77 Registered: July 2009 |
Member |
Dear all,
I have a few papyrus class diagrams in a particular project on which I have been experimenting Acceleo. Today, without any apparent reason, I am unable to open any of the papyrus models, neither the .di, nor the .uml files. On the former I get the exception reproduced below. All these models where created with Papyrus and some of them are a few months old, there hasn't been any change that could have corrupted the model.
This is happening on Helios; is there anything else I can do to further describe the issue?
Thank you.
org.eclipse.papyrus.resource.ModelMultiException: Problems encountered while loading one of the models.
----- exceptions : ----------
org.eclipse.papyrus.resource.uml.UmlModel : The class 'EModelElement' is not a valid classifier
org.eclipse.papyrus.resource.notation.NotationModel : The class 'EModelElement' is not a valid classifier
at org.eclipse.papyrus.resource.ModelSet.loadModels(ModelSet.java:283)
at org.eclipse.papyrus.core.editor.CoreMultiDiagramEditor.init(CoreMultiDiagramEditor.java:510)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManager.java:798)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:647)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:289)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2863)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2768)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2760)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2711)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2707)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2691)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2682)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:365)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:168)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:229)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:208)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:274)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:250)
at org.eclipse.jdt.internal.ui.navigator.OpenAndExpand.run(OpenAndExpand.java:49)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
at org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:185)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:845)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:843)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1131)
at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:462)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1235)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3540)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3161)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Caused by: java.lang.IllegalArgumentException: The class 'EModelElement' is not a valid classifier
at org.eclipse.emf.ecore.impl.EcoreFactoryImpl.create(EcoreFactoryImpl.java:105)
at org.eclipse.emf.ecore.impl.EFactoryImpl.create(EFactoryImpl.java:266)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createObject(XMLHelperImpl.java:874)
at org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.createObject(XMLHelperImpl.java:928)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2186)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1330)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1468)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1019)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:87)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1001)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:712)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:169)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:501)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1363)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2755)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:648)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:511)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:808)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:119)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:180)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1494)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1282)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at org.eclipse.papyrus.resource.AbstractBaseModel.loadModel(AbstractBaseModel.java:158)
at org.eclipse.papyrus.resource.ModelSet.loadModels(ModelSet.java:278)
... 61 more
FUDForum. Page generated in 0.13591 seconds
