| Eclipse 3.x RCP Editor throws exceptions on e4 [message #872970] |
Thu, 17 May 2012 03:46  |
Rajesh KP Messages: 13 Registered: May 2012 |
Junior Member |
I could bring up my Eclipse 3.x application with the help of some documentation and from this forum.
One another problem that I've is, I get the below exceptions when I try to open my Eclipse 3.x editor. Please help me again!
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. org.eclipse.search.searchActionSet
at org.eclipse.core.commands.contexts.Context.getParentId(Context.java:201)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.getLevel(ContextSet.java:48)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.compare(ContextSet.java:38)
at org.eclipse.e4.ui.bindings.internal.ContextSet$CComp.compare(ContextSet.java:1)
at java.util.Arrays.mergeSort(Arrays.java:1293)
at java.util.Arrays.mergeSort(Arrays.java:1282)
at java.util.Arrays.sort(Arrays.java:1210)
at java.util.Collections.sort(Collections.java:159)
at org.eclipse.e4.ui.bindings.internal.ContextSet.<init>(ContextSet.java:76)
at org.eclipse.e4.ui.bindings.internal.BindingTableManager.createContextSet(BindingTableManager.java:88)
at org.eclipse.e4.ui.bindings.internal.BindingServiceImpl.setContextIds(BindingServiceImpl.java:236)
at sun.reflect.GeneratedMethodAccessor13.invoke(Unknown Source)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:77)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:106)
at org.eclipse.e4.core.internal.contexts.EclipseContext.processScheduled(EclipseContext.java:308)
at org.eclipse.e4.core.internal.contexts.EclipseContext.set(EclipseContext.java:322)
at org.eclipse.e4.core.internal.contexts.EclipseContext.activate(EclipseContext.java:608)
at org.eclipse.e4.ui.internal.workbench.swt.ShellActivationListener$3.run(ShellActivationListener.java:153)
at org.eclipse.e4.ui.internal.workbench.swt.ShellActivationListener.deactivate(ShellActivationListener.java:145)
at org.eclipse.e4.ui.internal.workbench.swt.ShellActivationListener.handleEvent(ShellActivationListener.java:76)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1483)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1275)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1300)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1281)
at org.eclipse.swt.widgets.Shell.filterProc(Shell.java:750)
at org.eclipse.swt.widgets.Display.filterProc(Display.java:1495)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Native Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS.java:2332)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3177)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.views.log.EventDetailsDialog.open(EventDetailsDialog.java:180)
at org.eclipse.ui.internal.views.log.EventDetailsDialogAction.run(EventDetailsDialogAction.java:98)
at org.eclipse.ui.internal.views.log.LogView$15.doubleClick(LogView.java:535)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:845)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:843)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1477)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1246)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:249)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:246)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:307)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1276)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3554)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3179)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1017)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:911)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:582)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:537)
at com.novell.idm.rcp.DesignerApplication.start(DesignerApplication.java:118)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
org.eclipse.core.commands.common.NotDefinedException: Cannot get the parent identifier from an undefined context. org.eclipse.ui.edit.text.actionSet.convertLineDelimitersTo
-KPRajesh
| Re: Eclipse 3.x RCP Editor throws exceptions on e4 [message #873403 is a reply to message #873395] |
Fri, 18 May 2012 02:41  |
Junior Member |
Sorry.
A correction is that I'm seeing the above mentioned exception problem in both M6 as we'll as M7 builds.
Actually I'm getting exception when I "open an existing editor" from my RCP application during createPartControl while trying to create actions for CUT operation and I'm suspecting the above exception.
When I create similar new editor it goes through.
-KPRajesh
FUDForum. Page generated in 0.01735 seconds
