Home » Modeling » M2T (model-to-text transformation) » [Acceleo] 2 Debugging Environment behaving differently
[Acceleo] 2 Debugging Environment behaving differently [message #872737] Wed, 16 May 2012 14:10 Go to next message
Alain Lavoie is currently offline Alain Lavoie
Member
I have two separate Acceleo projects.
I compared the manifests, that are identical except for the project name
I compared generate.mtl which have the same headers,...
One parse Classes
One parse Packages
The new project (parsing Packages) does not stop on breakpoints
A file is generate and I can view its output, but which is more
handy, I cannot stop into the new project.
Any idea why ?
Thanks in advance.
Re: [Acceleo] 2 Debugging Environment behaving differently [message #872816 is a reply to message #872737] Wed, 16 May 2012 18:00 Go to previous messageGo to next message
Member
Alain Lavoie a écrit :
> One parse Classes
> One parse Packages
> Any idea why ?
[Solved]
Solution:
For some reasons, erasing the acceleo Project from the Package explorer,
did not remove the directory on disk.
I went looping over erasing and recreating without restarting
eclipse... many times, before erasing by hand the directory on disk.
Recreating my project after deleting the directory by hand fixed the
problem.
Regards.
Re: [Acceleo] 2 Debugging Environment behaving differently [message #874617 is a reply to message #872816] Mon, 21 May 2012 05:02 Go to previous messageGo to next message
Stephane Begaudeau is currently offline Stephane Begaudeau
When you are removing a project from the workspace, a popup appears to ask you if you want to remove the project from the filesystem too, by default it will not remove it from the filesystem, maybe that's where your problem is coming from.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
[Updated on: Mon, 21 May 2012 05:04]
Report message to a moderator
Re: [Acceleo] 2 Debugging Environment behaving differently [message #875887 is a reply to message #874617] Wed, 23 May 2012 09:52 Go to previous message
Member
@Stephane Begaudeau
I am sure I did erased the project with the popup setting correctly,
though. Could be my mistake. Thanks
Previous Topic:How to retreive a list of attribut in a certain order
Next Topic:[Acceleo] Bibliographic references
Current Time: Fri May 24 03:34:40 EDT 2013
Powered by FUDForum. Page generated in 0.01704 seconds
