| ecore model from .di [message #870325] |
Mon, 07 May 2012 12:14  |
elhache elhache Messages: 1 Registered: May 2012 |
Junior Member |
Hi All,
I would like to experiment model transformation technologies. ATL, actually.
My ultimate goal is to create a sequence diagram using Papyrus diagram, then, to use
ATL to produce a state diagram model. The final step is to convert the obtained diagram into Papyrus format for visualization.
My Question is : how to obtain (grammatically, or with an existing tool) an ecore model from a Papyrus model i.e., .di ?
I need that because ATL takes an ecore model as input.
Thanks a lot.
el
| Re: ecore model from .di [message #871965 is a reply to message #870325] |
Tue, 15 May 2012 04:23  |
Camille Letavernier Messages: 225 Registered: February 2011 |
You should not try to convert a Papyrus model to an Ecore model. You should use the UML.ecore metamodel instead.
For your transformations, you should work with *.uml files (ie. the semantic files), which conform to the UML.ecore Metamodel. You can also work with notation.ecore (from ) + *.notation files for your diagram visualisations, although it is probably a lot more complicated (*.notation files are not trivial at all).
UML Metamodel (semantic): http://www.eclipse.org/uml2/4.0.0/UML (UML.ecore, from org.eclipse.uml2.uml)
Notation Metamodel (diagrams): http://www.eclipse.org/gmf/runtime/1.0.2/notation (notation.ecore, from org.eclipse.gmf.runtime.notation)
Camille
FUDForum. Page generated in 0.01540 seconds
