| Target definition import fails [message #840871] |
Tue, 10 April 2012 11:49  |
Thorsten Meinl Messages: 83 Registered: July 2009 |
Member |
Hi all,
I'm experiencing errors while importing a target definition with
Buckminster (probably it's more a PDE problem, i'm not sure yet). If
have a target definition file that contains a plug-in which has an
install action that creates a directory in the eclipse installation
directory (called "licenses", see below). Creating this directory fails,
when the features is installed into the target definition:
INFO: importtargetdefinition 'Professional_1.0.0.target'
Unable to load all units for Software Site container of target
[0]An error occurred while installing the items
[0.2]session context
was:(profile=TARGET_DEFINITION:resource:Professional_1.0.0.target,
phase=org.eclipse.equinox.internal.p2.engine.phases.Install,
operand=null --> com.knime.licenses 4.1.0.0032568,
action=org.eclipse.equinox.internal.p2.touchpoint.natives.actions.MkdirAction).
[0.2]Could not create directory
..../ws/.metadata/.plugins/org.eclipse.pde.core/.install_folders/1334072366393/licenses.
Any ideas how this can be fixed?
Thorsten
| Re: Target definition import fails [message #871549 is a reply to message #840871] |
Mon, 14 May 2012 07:51  |
Henrik Lindberg Messages: 2429 Registered: July 2009 |
Can you post the instructions used to publish action that creates the
directory? (Is it being executed in the correct phase etc...)?
- henrik
On 2012-10-04 17:49, Thorsten Meinl wrote:
> Hi all,
> Cheers,
> Thorsten
FUDForum. Page generated in 0.01819 seconds
