Home » Eclipse Projects » Buckminster » Difference between 3.6 and 3.7?
Difference between 3.6 and 3.7? [message #802222] Sun, 19 February 2012 11:26 Go to next message
Wim Jongman is currently offline Wim Jongman
I had a solid build based on Buckminster 3.6. After installing Buckminster 3.7 the build is failing.
ERROR [0019] : java.io.FileNotFoundException: /home/targets/rdp8/plugins/com.ibm.etools.iseries.rse.ui_8.0.0.v20101014_1730/.project
The plugin is part of my target environment:
<target includeMode="feature" name="TDOMS Base Target">
<locations>
<location path="/home/targets/rdp8" type="Directory"/>
<location path="/home/targets/eclipse36" type="Directory"/>
</locations>
</target>
There is no .project at this location because it is not a source bundle.
any suggestion on how I can fix this?
Thanks in advance,
Wim
Re: Difference between 3.6 and 3.7? [message #802228 is a reply to message #802222] Sun, 19 February 2012 11:37 Go to previous messageGo to next message
Here is some additional stuff about this bundle
com.ibm.etools.iseries.rse.ui:osgi.bundle/7.5.0: Using resolver Local resolver
com.ibm.etools.iseries.rse.ui:osgi.bundle/7.5.0: Trying provider local(materialized)
No materialization found for com.ibm.etools.iseries.rse.ui:osgi.bundle/7.5.0
com.ibm.etools.iseries.rse.ui:osgi.bundle/7.5.0: Trying provider local(workspace)
No open workspace project found that corresponds to com.ibm.etools.iseries.rse.ui:osgi.bundle/7.5.0
com.ibm.etools.iseries.rse.ui:osgi.bundle/7.5.0: Trying provider local(target)
com.ibm.etools.iseries.rse.ui:osgi.bundle/7.5.0: Found match 8.0.0.v20101014_1730
Re: Difference between 3.6 and 3.7? [message #871192 is a reply to message #802228] Fri, 11 May 2012 07:32 Go to previous message
Bob Reynders is currently offline Bob Reynders
Have you solved this problem?
We are having exactly the same problems with a bundle that resides in our target platform and I can't find anything on this problem other than this post.
ERROR   [0099] : java.io.FileNotFoundException: <snip>\.metadata\.plugins\org.eclipse.pde.core\.bundle_pool\plugins\de.mpicbg.tds.knime.scripting_1.1.0.201112121427\.project
Previous Topic:Buckminster materialize from local maven repository
Next Topic:building Hello Xml World from Jenkins
Current Time: Fri May 24 05:18:14 EDT 2013
Powered by FUDForum. Page generated in 0.01856 seconds
