| Can not select menu item of Eclipse SDK 4.2 M7 [message #871131] |
Fri, 11 May 2012 01:06  |
Xiaoying Gu Messages: 51 Registered: July 2009 |
Member |
I found that select menu operation fails in eclipse 4.2M7.
I defined an AUT that starts eclipse SDK 4.2M7, then defined a simple test case that select the menu bar using IndexPath: 1/1/1, which will active the new project dialog.
This operation just failed as "Not Found". The same case runs fine on the eclipse 3.7.2 release.
I'm using the Jubula 1.2.0 release. Any ideas?
FUDForum. Page generated in 0.06500 seconds
