| Compatibility Layer [message #870884] |
Thu, 10 May 2012 03:21  |
Daniel Zimmermann Messages: 10 Registered: July 2009 |
Junior Member |
yesterday I tried the compatibility layer and finally got my "old" 3.x based Application up and running.
So far so good, but there are a couple of problems I couldn't either solve or even understand:
1) The toolbar icons from my ApplicationActionBarAdvisor are at the place, where the perspective bar would be, if I would have it activated. If I activate the perspective bar, the toolbar icons are even on the right side of it.
It looks like: <Quick Access> ( | <Perspective>) | <Toolbar>
I would like to know, if you ever encountered this kind of Problem.
2) The other annoying thing is a "Nameless Window": The Title Area of the Window is empty resulting in a "Nameless Window" on my Ubuntu Unity top panel, when focused.
I tried to use my own version of a LegacyIDE.e4xmi to solve this, but it seams, it's never even checked from within my plugin.xml, which - by the way - looks like:
<extension
id="product"
point="org.eclipse.core.runtime.products">
<product
application="com.mycompany.p2p.tracker.rcp.pfs.ssdtool.application"
name="PFS Customer Platform">
<property
name="windowImages"
value="icons/ipqlogo_16.gif,icons/ipqlogo_32.gif,icons/ipqlogo_64.gif,icons/ipqlogo_128.gif">
</property>
<property
name="appName"
value="PFS Customer Platform">
</property>
<property
name="applicationXMI"
value="com.mycompany.p2p.tracker.rcp.pfs.ssdtool/LegacyIDE.e4xmi"><!-- <plugin-id>/<e4xmi-file> -->
</property>
<property
name="cssTheme"
value="org.eclipse.e4.ui.css.theme.e4_default">
</property>
</product>
</extension>
...oh and yes, I gave the TrimmedWindow a label wihtin the LegacyIDE.e4xmi
So I don't quite understand, why my settings seem to be ignored during the application startup.
Could you give me some hints on those problems?
Greetings,
Daniel
[Updated on: Fri, 11 May 2012 03:13] Report message to a moderator
| Re: Compatibility Layer [message #871146 is a reply to message #871003] |
Fri, 11 May 2012 03:12  |
Junior Member |
That works! Thanks!!!
By the way, even if I haven't changed a single line of code, the Label from TrimmedWindow is now properly used. I assume, that it was a chaching problem, when I started the application from within Eclipse.
Greetings,
Daniel
FUDForum. Page generated in 0.01863 seconds
